JJR front/dump from just jap. didnt fit up right need to be cut and re-welded, the bend is wrong and hits the crossmember...
I'm thinking of getting the bellmouth from jjr too... but i thought it was suppose to be a bolt on jobbie... most others that have fitted it have had no problems?
  • Replies 90
yeah i thought the same .. heard the r33 fits up perfectly to the series 2
Guys are you confusing the bell-mouth (non split) with the split pipes here? I contacted JJR and they told me the splits have issues, need modification to fit properly, but that the bellmouth pipes (non-split) fit stagea without modification.
Edited by DaveB
ahh finally exhaust is on, and pics have been taken
3" Xforce hiflow cat
Xforce MID muffler
Xforce read muffler with twin 3"tips
That's it, that's what I'm after for my S2! I'm in same boat - want to buy a jap system but they're all cannons. Do you have the part number of the rear x-force muffler? Stuff with twin tips like that seems pretty rare...
C'mon guys don't be weak.. Go twin 4" cannons :yes:
I've got a 3" exhaust on my car going through to the twin 4" cannons and the young kids across the road recon my car is a beast caus it shakes there windows when i start it up lol
I also want to get a JJR Bellmouth dump.. not sure what dump i have on mine but i want something thats gonna free flow.. also i want to see if i can get 3" pipe with some mandrel bends for an intake pipe for the turbo.
Edited by SHIZNT
Quiet, but with a nice deep rumble while cruising... Open her up & the volume increases a fair bit.
Nowhere near shaking windows though :D
3" Fujitsubo Legalis R Evolution exhaust
3" Kakimoto front pipe
Stock dump because it contains the pre-cat which I have found it enough if you are selective about which fuel you use.
example: I filled up using Vortex98 last week and for the first time, my car smelt like rotten egg. Used 74L, put 15" of Vpower in, smell is much less.
Will be filling up tomorrow with ether Ultimate or Vpower. Smell should be gone completely.
Xforce MID muffler
Well I got the same problem as you when I did mine
JJR Bellmouth - didn't fit properly - exacly the same problem (and yes I brought the Stagea one) so it was rewelded
3" Magaflow Cat
Custom mid Muffler
Xforce 3" muffler with twin 3" twips
Sounds very good, has a nice exhaust note, still has that skyline sound and it's not too loud to be cop bait
xforce rear muffler numbers is MP01 . if you go to there webpage and click on the universal mufflers. wont be hard to spot it.
my middle muffle is faily big. got a nice note to it. cant hear it when i open it up tho. but been told it sounds nice from behind.
its going back today to get the front pipe fixed, gonna ask him to take out the muffler also .. see how it sounds then if its too 'droney', ill put it back on when i do the 100k service
on that note . ima go and make a video recording with twin mufflers so anyone interested can hear what it sounds like
C'mon guys don't be weak.. Go twin 4" cannons :ermm:
speak with ray at re about the pipe. he should have a fair bit left after doin my exhaust i'll check today heading in about 30mins
Cool mate, I'm heading down there on Thursday. Finally getting my spitfires put in then increase boost and back on the dyno! Hopefully i get some decent results.
That sounds awesome... thanks for that. Can't really tell very accurately because of the auto-volume thing on video cameras, but it sounds pretty quiet when you compare to the voices which seem to drown out the exhaust? Do you know the part number of your centre muffler?
um .... i will have it off the car by tomorrow. can always check the invoice and let you know when i pic up my car.
yeah you cant hear it as you would say on a r34 with cannon. idle is quiet, little bit of RB rumble, can tell the difference between the stock for sure,
new vid should be up thursday ... if not weekend latest with just the rear muffler
damn if only my work would allow youtube access...wanna compare you car to my car since it has roughly the same setup...the only exception that i only have one mid muffler
Nowhere near shaking windows though :P
Niiice... do you know where you can get a Legalis R cat-back system? They're 3 inch and fully stainless aren't they? The best I've been able to find is an exhaust shop that has done several stageas apparently, who said a stainless custom system would be around $850 + cost of exhaust tip(s) ($80 +). That in 3" stainless.
Edit: OOPS mis-read - you can only get that system for M35 :)
Edited by DaveB
just got one of my mufflers taken out , so now its a straight 3inch pipe from the cat to the rear muffler, and ya know what .. its quieter then a r34 with a cannon tip and mid muffler
so its staying the way it is :D i'll post a vid on youtube soon, so you can tell the difference
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
