Niiice... do you know where you can get a Legalis R cat-back system? They're 3 inch and fully stainless aren't they? The best I've been able to find is an exhaust shop that has done several stageas apparently, who said a stainless custom system would be around $850 + cost of exhaust tip(s) ($80 +). That in 3" stainless.
Edit: OOPS mis-read - you can only get that system for M35 :)
Perhaps give Henry @ RMS (http://www.rmsmotorparts.com.au) a call (03) 9872 6669.
Really nice guy and his prices are really, really good.
If there is something similar for an S2, he will find it (he is the only one who knew of & found my front pipe).
  • Replies 90
does any one know if i can put my 32 (gtr if that makes any difference) on to my s2 stag?? i no there will be some modding involved just how much?
its a cat back!
Edited by chef_stagea
Got cat-back done the other day... I fitted a stainless 3" split front/dump with my hi-flow turbo and 5" body 3" flanged hi-flow cat' myself, and it wouldn't *quite* line up with the stock cat-back (flange angled a little too low on the cat) but with a bunch of gaskets, one bolt, and some forcing I was able to make it hold just enough for a risky drive to the exhaust shop... Exhaust Technologies was the only place I could get it done in time; they did it within the week :ninja: full 3" mandrel-bent mild system with stainless magnaflow ovals mid and rear. Sounds bloody drony, and a bit loud perhaps... but bloody awesome :banana: Will post pics/video. System doesn't hang too low ('cept for the cat'), and the stainless twin tips they installed to match the originals really look awesome - long, so that you can't see the muffler from the rear. Clever that.
Just installed a custom 3" split dump/front pipe with metal cat by Liverpool exhaust for M35 AR-X. The result is very noticeable with more torque and quicker response than stock. Turbo spooling is also very audible as well, perhaps a bit too loud for my liking, but the gain is well worth it.
I still have the stock cat-back as well.
I had exactly the same experience with C34 re: louder turbo spool. But I agree, increased power & marginally better fuel economy means I'll put up with it :P
better fuel ????
i was goun 450-500 without the exhaust.
now lucky to see 410 .... !!!
Lol yeah I was just hoping for a little better consumption at cruise. But if I take advantage of the extra power then I have to expect worse consumption... so far consumption is worse :P But hoping if I go on some long trips it will show improvement. Spend most of my time driving in limp-mode anyway with the transmission stuck in 3rd gear 'cause of my (* ignition circuit problem (cuts out or shorts or something randomly). When/if I ever fix that it might improve.
Im looking at a 3" turbo back system for my s1.
Am thinking of going down the lines of a just jap bellmouth stainless front/dump and hopefully this http://cgi.ebay.com.au/Skyline-cat-back-ex...A1%7C240%3A1318
I have just bought a pair of brand new clear side indicators c/w new amber bulbs straight plug in job for NZ$39 the pair from here:
http://www.trademe.co.nz/Trade-Me-Motors/C...n-194674347.htm
If you sign up to Trade Me (it is possible from Aus) you could buy direct or otherwise I could get some for anyone interested. But the relevance to this thread is that he also stocks a range of exhaust tips (steel, not stainless) from about $75. If you look on his entry above and click on "seller's other listings" you can see the tips but not shown are a number of twin tips (a range of single entry sizes including 3in) coming out of one muffler - cost about $150.00. I just got in today before he closed for Xmas and i don't know when he will open but when he does i will go in and take a few pics and post them up.
If you want here is an HKS Stagea specific muffler: http://www.trademe.co.nz/Trade-Me-Motors/C...n-194346844.htm
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
