Firstly, i love my car (s1 stag), dont get me wrong, but there are a few issues. Mainly due to my excitedness/haste (read: foolishness) in buying i suspect.
1. I dont have an original stag key. I have a craaapy mr minit looking cut key, and crappy little press in immobiliser. I'm assuming car wasn't shipped with the key or something?
2. My power steering pump is making an inordinate amount of noise. (noticable mainly due to 3.)
3. Left side speakers blown.
4. Rust on INSIDE of door mirrors
5. Drivers side door mirror requires manual assistance in folding in/out
6. Twice now, car has stalled driving in shopping centre car parks (will check out fuel filter this weekend)
7. After 30mins - 1hrs driving it bogs down when accellerating from idle (auto trans fuild hot maybe?)
8. Current auto issues are making me save for a manual s2 already.
9. There are water marks on the top of the visors, and the rear portion of the roof has begun to hang down at the join. i'm suspecting that there may have been a leak through the roof although there is no visible rust or anything there.
10. It's already been back to have a belt changed because it almost deafened me with its squeal while my head was under the bonnet
so, i'll call it personality, it sounds more positive that way :blink:
i have my work cut out for me i think :)
https://www.sau.com.au/forums/topic/230800-stagea-issues/
Just remember you bought a 12 year old car and although most cars come from japan with low km's 12 years of sitting in the snow and rain will do damage,it could be worse you could of bought a 12 yr old commodore and be doing alot more repairing. Stick with it and be rewarded with a fun car im loving my stag and although it needs some attention i wouldnt trade it for the world atm.
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4054416
My car came with a key with built in locking/unlocking (maybe an optional extra?) if you can find someone to check via FAST (i Can't) you may be able to find out. I tried to buy another key but was quoted $300 from Nissan
Rusty doors under the mirrors is a Stagea thing (but the ONLY rust on my car). The sooner fixed the better. Door panels off, mirror off (maybe time to o/haul or replace the motor) weld in steel and replace or dry foam and put waxy stuff (panel beater told me) to prevent further rusting.
see above
Unlikely but see DIY section for installation of cooler - check fliud to see if its dirty and needs replacing
so, i'll call it personality, it sounds more positive that way ;)
i have my work cut out for me i think :teehee:
Not just a car but a past-time!
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4056881
hahaha I get really embarrassed by it.. damn car making me blush hahahaha
heh, mine squeals no longer, the offending belt got replaced and my ears have finally recovered ;)
apparently you can get a de-glazing compound to sort out the squeak on the belts if they're not too far gone, where you'd get it from i have no idea though :)
heading back to the dealership with a list of things to have sorted out tomorrow, i imagine not many will be fixed, but even if its only 1 or two then thats 1 or two i dont need to fix :(
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4059378
http://www.skylinesaustralia.com/forums/Ca...vs-t230750.html
I found this issue to be my AFM but it may be different to yours
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4059910
Yeah bro,
Happened to me on my first stag with the standard factory bov and everyone has a theory on how to fix this issue.
It is common on autos but can occur with manuals aswell. This caused lots of probs and I couldnt pin point it and also changed the afm.
I had the same prob when I went open atmospheric with an Apexi dual chamber and had to plumb back the right air flow on deceleration.
A aftermarket computer engine management system or SAFC II can fix this or you need a full plumb back system, I had the same prob on my GTiR with a SARD R2D2 and chose a HKS Eids.
Either of these will fix the idle/stalling prob, just depends on how much you want to spend and how far you want to go with later tuning and cost.
The SAFC II was the way to go when on the cheap, just up to +1 deceleration air.
Also leetom is right about the squealing alternator belt, just adjust, a new one will do it aswell.
Stageas are hard to find without rust and doors are usually common, its more along the lines of least amount of rust, mine is pretty clean though.
All stags need a full major service and overhaul when bought considering wear and tear on the usual items, it cant be avoided on a 10 year+ car.
As I said my second stagea..lessons learnt and still could maintain full open atmospheric venting..PSSSHHHTT!!
Edited by nismokid
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4060482
  • 8 years later...
Super Cheap sells a spray to fix squealing belts. Saw it in the shop today when I was looking for dielectric grease for my coils.
Shit this is an old post. Ha ha ha so tired.....
Edited by TMLP
  • Like 1
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-7787108
Blast from the past ;)
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-7787271
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
