Firstly, i love my car (s1 stag), dont get me wrong, but there are a few issues. Mainly due to my excitedness/haste (read: foolishness) in buying i suspect.
1. I dont have an original stag key. I have a craaapy mr minit looking cut key, and crappy little press in immobiliser. I'm assuming car wasn't shipped with the key or something?
2. My power steering pump is making an inordinate amount of noise. (noticable mainly due to 3.)
3. Left side speakers blown.
4. Rust on INSIDE of door mirrors
5. Drivers side door mirror requires manual assistance in folding in/out
6. Twice now, car has stalled driving in shopping centre car parks (will check out fuel filter this weekend)
7. After 30mins - 1hrs driving it bogs down when accellerating from idle (auto trans fuild hot maybe?)
8. Current auto issues are making me save for a manual s2 already.
9. There are water marks on the top of the visors, and the rear portion of the roof has begun to hang down at the join. i'm suspecting that there may have been a leak through the roof although there is no visible rust or anything there.
10. It's already been back to have a belt changed because it almost deafened me with its squeal while my head was under the bonnet
so, i'll call it personality, it sounds more positive that way :blink:
i have my work cut out for me i think :)
https://www.sau.com.au/forums/topic/230800-stagea-issues/
Just remember you bought a 12 year old car and although most cars come from japan with low km's 12 years of sitting in the snow and rain will do damage,it could be worse you could of bought a 12 yr old commodore and be doing alot more repairing. Stick with it and be rewarded with a fun car im loving my stag and although it needs some attention i wouldnt trade it for the world atm.
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4054416
My car came with a key with built in locking/unlocking (maybe an optional extra?) if you can find someone to check via FAST (i Can't) you may be able to find out. I tried to buy another key but was quoted $300 from Nissan
Rusty doors under the mirrors is a Stagea thing (but the ONLY rust on my car). The sooner fixed the better. Door panels off, mirror off (maybe time to o/haul or replace the motor) weld in steel and replace or dry foam and put waxy stuff (panel beater told me) to prevent further rusting.
see above
Unlikely but see DIY section for installation of cooler - check fliud to see if its dirty and needs replacing
so, i'll call it personality, it sounds more positive that way ;)
i have my work cut out for me i think :teehee:
Not just a car but a past-time!
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4056881
hahaha I get really embarrassed by it.. damn car making me blush hahahaha
heh, mine squeals no longer, the offending belt got replaced and my ears have finally recovered ;)
apparently you can get a de-glazing compound to sort out the squeak on the belts if they're not too far gone, where you'd get it from i have no idea though :)
heading back to the dealership with a list of things to have sorted out tomorrow, i imagine not many will be fixed, but even if its only 1 or two then thats 1 or two i dont need to fix :(
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4059378
http://www.skylinesaustralia.com/forums/Ca...vs-t230750.html
I found this issue to be my AFM but it may be different to yours
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4059910
Yeah bro,
Happened to me on my first stag with the standard factory bov and everyone has a theory on how to fix this issue.
It is common on autos but can occur with manuals aswell. This caused lots of probs and I couldnt pin point it and also changed the afm.
I had the same prob when I went open atmospheric with an Apexi dual chamber and had to plumb back the right air flow on deceleration.
A aftermarket computer engine management system or SAFC II can fix this or you need a full plumb back system, I had the same prob on my GTiR with a SARD R2D2 and chose a HKS Eids.
Either of these will fix the idle/stalling prob, just depends on how much you want to spend and how far you want to go with later tuning and cost.
The SAFC II was the way to go when on the cheap, just up to +1 deceleration air.
Also leetom is right about the squealing alternator belt, just adjust, a new one will do it aswell.
Stageas are hard to find without rust and doors are usually common, its more along the lines of least amount of rust, mine is pretty clean though.
All stags need a full major service and overhaul when bought considering wear and tear on the usual items, it cant be avoided on a 10 year+ car.
As I said my second stagea..lessons learnt and still could maintain full open atmospheric venting..PSSSHHHTT!!
Edited by nismokid
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-4060482
  • 8 years later...
Super Cheap sells a spray to fix squealing belts. Saw it in the shop today when I was looking for dielectric grease for my coils.
Shit this is an old post. Ha ha ha so tired.....
Edited by TMLP
  • Like 1
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-7787108
Blast from the past ;)
https://www.sau.com.au/forums/topic/230800-stagea-issues/#findComment-7787271
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
