hey guys... time has come to part with my 32 unfortunately. dont want to sell her but I have come into a fat tax bill that needs urgent attention, and my time of having a killer car has to end.. for now at least :)
Details:
1993 Nissan Skyline
R32 GTST (turbo)
Maroon
131,000kms
Lowered
Mags
3" exhaust
Apexi air filter pod
EVC green brake pads (these dominate)
GTR body kit (front bar, skirts)
GReddy type M front mount intercooler
Momo steering wheel
HKS turbo timer
Pioneer deck, with 4x 6" pioneer splits and tweeters
Serviced every 5000 kms with minor service and every 10 000 kms with major service (log book to prove).
Timing belt replaced at 100 000kms
Plenty of cash spent on her!
Mechanically, I have not had one single problem with this car. It runs like an dream.Always run on stock boost levels which is 7psi i think. So if u were to get a boost controller you could easlier get more power of this car considering all the other mods such as intake, exhaust, and intercooler have already been done.
Much loved car with a genunie reason for sale..
$12900ONO. All reasonable offers considered!
James - 0431 557 393 or email - garno (@) iinet.net.au
Western suburbs. PERTH
Edited by jamesg
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
