The other day I noticed that my RB25DET motor started making this horribly loud whistling sort of noise, which seems to come on on just a little bit of throttle (~10hg vacuum or so), and then goes away when I floor it (at about 4-7psi it stops and goes back to normal).
I checked all the vacuum hoses I could see, and tightened up a few intercooler pipes which were loose, a mate reckons that it could either be an exhaust manifold or v bend on the exhaust leaking, due to the fact that I've got a KKR 480 turbo on it, and they are prone to this?
Has anyone else had the same problem? I tried searching but the threads it came up with weren't really applicable to my dilemma.
It dosen't seem to have gotten any worse, its more just embarassing driving around in a Skyline that sounds more like an EA Falcon!
Im hanging out until I go home next week (500km away) to get this looked at as it dosen't seem to be getting any worse or affecting how the car drives, but I thought I'd ask on here in case its something mind bogglingly simple to fix!
hey
yeah i got one of these turbos on my r32 too..
mine did it at the start for a while too, but i knew i had a massive exhaust leak.. make sure all it is all tightend properly etc.
but mine still makes a slight whistling sound neways...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
