Make:nissan
Model:skyline
Milage:159000kms 110000 on engine
Transmission:5 speed manual
Colour:silver
Complied?yes
RWC supplied?yes
Currently registered?yes
Price:$19000
Contact:0419284730
Comments / Modifications:this car is very unique. its makeing more than 250rwkw and sounds very different from the others. owned by a mature owner Its serviced every 3000kms,the engine was tested and had compressoin between 250 and 260, all gaskits have been changed eg exaust,turbo,manifold,head gaskit.etc The clutch and gearbox have been recently replaced. list of modificatoins front mount tube and fin intercooler garrett 2835r turbo full 3inch exhaust including dump pipe power fc tomei injectors 550cc 500hp fuel pump custom air box,intake,cold air inductoin and catch can 18inch axis rim 255 rear 225 front carbon fibre wing can be changed for standard wing hidden blow off valve can be changed to plumb back flame thrower blow up to a metre out jun style font bar fully tinted windows this car has been tuned at unigroup i have reciepts for everything have spent over $26000 on this car.the car might have some kms but the engine is 110000kms ,new owner will be very happy with the 32 any questions please give me a call may swap for a ute or a small 4cylinder
Images:
https://www.sau.com.au/forums/topic/230876-r32-skyline-rb25/
  • 3 weeks later...
  • 1 month later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
