well basicly o couldnt tune my car to its petensial because i had 550cc injectors and the emange blue cant tune them that well which robbed a lot of power.like i it could only be tunes to 12 psi ;( so i want an ecu that can tune bigger injectors and get the best out my car>>> any ideas ... i have heard the wolf 3d is good and that there is a new emanage ultimate but dunnoo any thing about that
dont go with power fc there crap cant tune them that good look up ems either 6860 or 8860
thats my opinion i have the 4424 stinger in my rb26 powerd 180sx and the 2 i sugestd are the new versions
http://www.enginemanagementsystem.com/frameindex.htm
Edited by GTR180
I assume you are talking about your own tuning ability's as there are plenty of big hp cars running a power fc, you dont get big hp without extensive tuning.
I can only contribute to a process of elimination...
I have a HKS F-Con Pro-V but I can't recommend it because the expert tuner from Japan only comes here periodically;
despite it running well. I can't touch it!
Cheers, T
weren't HKS opening up a couple of places here which could tune the F-Con or something to that effect?
Not sure...
Please let me know!
Even reluctant to dyno the thing atm.
Bit paranoid about upsetting something that's going ok.
Cheers, T
hey original poster
have a chat to sau business seller Toshi
he does an ecu mod adapter plate and a custom tuned chip for air fuel ign.timing etc etc
very very worth while
my awd auto rb25det s1 stagea (s2 r33 engine, etc)
keep the emanage to adjust the tune on the dyno
my stagea had 180kw, did the ecu chip, on dynomade 82kw lol, backed off safc/sitc piggybacks and fuel pressure, made 190kw
getting retuned today as Ive fixed the massive boost drop with a hiflowing cat converter (Random technologies, lol, but 617cfm...)
have 555cc injectors to go in, were going in today but we'll see how it goes, havent got much $ really atm, so probably drop them in next service/tune 4000kms time
tuner, shaun @ boostwerks, hasnt got a problem in setting up the injectors to run... mind you they are stock high flowed deatschwerks 555cc items. for sale at cost if anyone really wants them (I dont need massive power figures, just a good tune).
anyways. have a chat to Toshi and see what he can do for you. pretty cheap way of getting your auto running well. :(
WTF ?
The emanage blue does a great job for what it is. Have you actually tried one ?
Whack the emanage on, someone who knows what they are doing will be able to get the car running great! With the Auto i would only suggest a emanage for anything thats not totally worked off its head, and even if it is.. go the Ultimate
Wow - some real experts on here!
:P
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
