id like to get a response though!
im keen, just wanna know if i was accepted or not....i dont wanna be 2nd best option though :thumbsup:
they wont know if your in till they have enough cars, as they only wont the most powerfull cars in the comp
  • Replies 281
Probably a stupid question, but does boost worx have a 4wd dyno? May have to get the 260 down there to confuse some commo drivers! lmao!
And if any calais turbos turn up...since they run a Nissan RB30 then they should be on the import side!
Edited by GRIM_R32
No :P we will have to drop our shafts
All enteries will be classed by the chassis. (As a Holden driver will still have massive Holden stickers on the rear window even if it's a Nissan motor).
I have not posted on cailasturbo.com.au yet, but thanks for the tip.
We have some spots on imports still, but it's filling up quickly. The 210-220 mark might be enough for the moment, thats decent power dude.
Thanks for all the support guys!
thats what sponsors are for, you don't actually pay them to supply prizes unless you cant be assed asking anyone for sponsorship then you prizes come out of profit no profit = no prizes just bragging rights
Its at cost so there will be no prizes..
Slug another $5 and offer some prize. haha Brian sorry bud you can't win. :P
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
