id like to get a response though!
im keen, just wanna know if i was accepted or not....i dont wanna be 2nd best option though :thumbsup:
they wont know if your in till they have enough cars, as they only wont the most powerfull cars in the comp
  • Replies 281
Probably a stupid question, but does boost worx have a 4wd dyno? May have to get the 260 down there to confuse some commo drivers! lmao!
And if any calais turbos turn up...since they run a Nissan RB30 then they should be on the import side!
Edited by GRIM_R32
No :P we will have to drop our shafts
All enteries will be classed by the chassis. (As a Holden driver will still have massive Holden stickers on the rear window even if it's a Nissan motor).
I have not posted on cailasturbo.com.au yet, but thanks for the tip.
We have some spots on imports still, but it's filling up quickly. The 210-220 mark might be enough for the moment, thats decent power dude.
Thanks for all the support guys!
thats what sponsors are for, you don't actually pay them to supply prizes unless you cant be assed asking anyone for sponsorship then you prizes come out of profit no profit = no prizes just bragging rights
Its at cost so there will be no prizes..
Slug another $5 and offer some prize. haha Brian sorry bud you can't win. :P
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
