  • Replies 281
it's ok i got a fantastic mechanic! anyway what brand are they?
OEM Mazda 550cc. Happily supporting 300+rwkw on my RB25DET at the moment, and up until ~17th Nov 08. Then out they come and in go the 780's.
^ bump ^
We've had a couple cars pull out due to engine trouble, not ready or being upgraded on the day of the dyno.
If your interested in running on the dyno we need you!
Domestics are only 2 cars short, however we are still accepting entries from higher power cars also.
Entries officially close on the 14th on November.
Cost is $30.
Date: 22nd November.
Time: 10AM till 5PM.
Apply here:
http://toyotacarclub.net/events/domvsimp/
Thanks guys!
I'm interested. However, my car will be undergoing a few minor upgrades at Boostworx around the 17th-20th of this month, and although it 'may' be ready in time, I won't really know until after the close date - the car could even still be there when the dyno day is on.
^ bump ^
Cost is $30.
Apply here:
Thanks guys!
can you post up bank details i cant seem to find the email
Me but i dont think i will get my new pfc in, in time i was ment to pick it up today but the guy couldnt meet me and now he is express posting from milicent or round that way, then i have to see if Shaun can wire it up as its a GTR pfc
Sorry Matt, I'm just reading this.... didn't it do that a couple years ago???
Hope to catch you soon!
Ha-ha fair call, Will :( What can I say, it started as a simple $3k turbo upgrade in 2006 and has since turned into a... ummm... maybe $10k long term project. The old set-up that ran the numbers listed in my sig' is not even close to the 'real world' grunt of the new set-up, and the new set-up isn't at full potential yet. At best I reckon the old set-up would've made 260-270rwkw on the BW dyno.
Unfortunately it won't be ready for the dyno day on Sat, so I'll merely be a spectator. Be good to catch up though mate.
it will work madaz, i got a gtr pfc in my r33 gtst
im thinkin of coming to watch/support the japs
im goin on a fishing/drinking trip friday night so not sure what sort on condition ill be in :)
chris, steve has GTS4t, maybe i little different.
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
