so this cars actually engineered/mod permitted?
coz a yellow sticker would turn out absolutely expensive for you?
is top racing doing the tuning inhouse?
ps. do you know how much the clutch set you back?
seems to be recommended by alot of workshops here in WA
Edited by R32 Driver
  • Replies 90
they did one in a vl before but using a r33 head. Its more of a drag car and pretty serious stuff. I think after doing my car them boys could do another with their eyes closed and upside down. And any doubts they had they made sure to take the extra precautions to ensure max reliability.
Edited by drgnball34
theres problems gettin the engine stared. Its only running on 2 cylinders. They pin pointed it dwn to a possible faulty hks ignition amplifer?? Even thou its brand new! And apparently its not the 1st unit they encountered with the same prob. So they goin 2 plug up the orignial harness n see. Has any1 heard of the same thing happing and could there also be another factor?
That's a very weird problem to have... my 2630 started first turn, was a little rattly for the first 5 seconds, then came to life like normal.
I HIGHLY doubt your HKS Twin Power is faulty unless you guys did a splice/dice wiring job - you just got the plug-in loom right?
My mates HKS ignitor failed pretty quickly on his SR, not when it was brand new though.
So you never know, could be a faulty ignitor.
Keep us updated, very interested to see how she goes.
Edited by PM-R33
brand new spitfires/plugs. Im sure they would of checked them 1st. I think it would b a process of elimination with the obvious first. U would think paying top dollar for brand name parts known the dam stuff bloody works to start of with
I'd have thought that they'd at least have made sure it fired up properly before calling you down for an inspection... but I know your pain after such a long time, I wasn't there when the car was first started up - but I had it streamed realtime onto the internet so I could watch at work :D
Thanking my lucky stars it all went as planned...
yep she's all fired up and running. Still very curious as to why its not starting with the hks amplifer thou. Something to look into down the track as its not needed now. Engine is very loud and cams are lumpy indeed which surprised everyone. Idle is just pure sex. Too paranoid to drive much as absolute cop magnent. Run in tune makes .8 bar at rev limit of 4k rpm. Not as laggy as expected. It is so drivable with the extra torque and clutch is so smooth. Would never know its rated 1000hp.
theres at least another 6wk waiting peroid for the haltech plug and plug to be released. Dont know weather i should just piggy back the standard ecu or go for another ecu all together. The tuner recommened the ems?
63k build and you were comtemplating an EMS... crazy. Nice build though, big fan of the NEO heads.
Edited by URAS
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
