  • Replies 100
love the last shot.. just wish you took it straight.. but then i realised you were probably trying to get the whole clock in with the 70-200mm lens?
Btw you using any filters? just curious thats all :D
ohh i love the 2nd last shot too!! nice work
Edited by siddr20
dodgsun - that midnight shot is awesome
Xmetal - nice shots - love that 1st fisheye one
Flower thing in the backyard (no PP)
have a close up too but its a bit dodgy (was too close so couldn't focus properly and DOF was too small anyway)
I would post up my photos....but probably easier for you to just check out where i have uploaded them to.
Theres a few there from Autosalon and my cruise Sunday just been (17th). Just click on the individual ones to enlarge, will take you to a new page, then click on it again to make it bigger :dry:
My deviantART Gallery
Howdy ya'll,
Its been a while :P
I got drafted to do some shots for the Herald at the City 2 Surf. I wont smash you with tonnes of them, just a couple :(
It was seriously just packed with people eeeeeverywhere
The back of the pack
Playing dodgems on William st
The clothes that people just left behind was incredible. Thousands of jumpers and tracksuit pants for miles
Im off to Vanuatu soon so I'll have prettier pics for you then :)
Edited by FullFrame
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
