It says on the QLD transport site that high-powered and performance vehicles include those with:
well my R34 25GT has no more than 8 cylinders, and it is not turbo-charged, I'm just not so sure about the third and fourth points, does my vehicle meet those requirements? Does anyone know?
Edited by NissanSkyline
https://www.sau.com.au/forums/topic/231097-restrictions/
Hey mate,
Your engine is not a rotary (RX7 is rotary, yours is an inline 6 i think), and manufacturers specifications are flywheel kw, which means your car would have to be 230-250kw at the wheels STOCK to be breaking this rule.
I think you should be ok mate!
Good luck
https://www.sau.com.au/forums/topic/231097-restrictions/#findComment-4059174
Your car doesnt have a modification that requires approval unless the engine has been changed or converted to manual or anything along those lines
Your car also isnt a rotary
Your car would not produce more than 200kw at the wheels and i doubt it would even do it at the flywheel
To add to this thread my mate has a non-turbo silvia with a RB20 that was converted to manual now i realise i may have answered my question but just wondering if anyone has had an experience with this and what the cops have done about it?
https://www.sau.com.au/forums/topic/231097-restrictions/#findComment-4059226
if ur car was ineligable then they wouldnt let you register it anyways.. so i wouldnt worry if ur not sure.. unless you are doing mods u shouldnt be :D:banana:
and yes no rotary .. its an inline 6
well because I just bought it, and its not registered under my name, so if I can't drive it legally, I'd be like HOLY CRAP!!!
https://www.sau.com.au/forums/topic/231097-restrictions/#findComment-4061197
If you brought the car and are transfering the rego you have 30 days to do it before the cops can break your ballz about it. If you are waiting for the rego to expire you are better off cashing in the plates or getting the previous owner to and re-registering it in your name asap. Hope this was helpful.
https://www.sau.com.au/forums/topic/231097-restrictions/#findComment-4062132
Hey mate,
Good luck
200kW @ engine doesn't mean 230-250kW @ wheels. Find me a driveline that makes power and I'll buy it :starwars: 200kW at the flywheel would be probably closer to 140-150rwkw.
https://www.sau.com.au/forums/topic/231097-restrictions/#findComment-4062374
    • Goddam! Thats the dream, neo heads seem hard to come by these days though, best I've seen is $2-3k or there's a full motor for $7k atm
    • Cheers for the input, 450kw on poncams is impressive! I assumed you'd need 264 or 272 for that power level, good to know you don't need to rev that high to hit it, just don't want to buy the cams etc then find out the hydraulic lifters suck haha The box will be getting reconditioned too, possibly an aftermarket gearset if it turns out they're toast, cheers I'll keep that in mind
    • I think definitely get a manual oil pressure gauge on it then. Double check if it's really dropping pressure that low.
    • yes sorry i should of spoke better, all sensors are grounded into their specific homes in the ecu, the ecu is then grounded to the chassis itself along with the EFI relay.
    • I'll check the wiring plan tomorrow. Now when you say ALL the earth's are to the chassis, is that including the sensor ground from the ECU? Certain items should not be grounded to the car/body/chassis, they should ground back to specific ground pins on the ECU.
