Just got the car back from a big-ish service incl all oils changed, fuel filters, gapped spark plugs etc and noticed that if I rev the engine and hold rpm somewhere between 1500 and 2500 rpm (I didn't try higher because I didn't want to attract attention to myself..) while the car is sitting idle in neutral, there's a muffled popping sound followed by a small shake (drive seat shakes noticably) every few seconds ..sometimes more than one in a row.
Like popcorn starting to pop ..just more muffled sound, and each pop shakes the car a bit. Is this just the exhaust note or should I be worried ? Detonation? Car's ecu was tuned before the service and it was NOT pinging/detonating...
The car's an R34 GTT with a turbo-back exhaust with a 3" catback (HKS SilentPower)
I never noticed this before but then again I never held the engine at 1500rpm for a few seconds before either..
https://www.sau.com.au/forums/topic/231130-popping-sound-and-car-shaking/
hm are you sure this is missfire? I searched for "Popping" last night and read a lot of older discussions and a lot of people seem to be under the impression that these popping sounds are normal on skylines and a few said it's probably due to running rich in that rev range .. no mentions of missfire anywhere.
I have no idea which plugs they put in ... I'm taking the car back to unigroup to have a listen to this. Could it be due to old fuel? car's been at the shop for was 2 weeks and only 1/4 of tank of fuel sitting in it
Edited by Delta Force
mine runs rough in the same situation. though in mine i put it down to section of the map thats never been tuned.
It's just a rich miss and nothing to be overly concerned about. It's something tune related and i wouldn't expect it's a result of a service. I'm pretty sure unigroup will tell you the same thing but it doesn't hurt to have it looked at if you are concerned.
Took it back to unigroup and as soon as Yavuz heard the popping at idle and low revs he said "yep it's misfiring" .. and that it's due to the small gap (0.75mm) so they regapped the spark plugs to 1mm and no more misfire/popping sounds ;-) Best of all ..they did it all for free! That's good service. Cheers.
Hey mate was yours the black r34 there? I was there about a week ago also.. had a safc tune. Mine is doing the same thing and yavuz said its normal with running small gapped plugs.. Funny i also hear it pop every now and then only on idle
just one thing ... Yav also mentioned that the car may misfire at higher rpms with bigger gap (and non stock boost). But for me that's not really an issue as a very rarely go above 4000rpm anyway (daily driver)
  • 3 years later...
sorry to bring up an old thread but i think my input is relevant and not worth starting a new thread.......
i have been experiencing the same muffled popping/rumble sound then shaking when car is idling after cold start. i noticed the rumble and shaking start to settle down after the engine oil had warmed up to about 90 degrees.
couldn't figure out what was wrong, then 2 weeks later the check engine light came. it turned out an exhaust leak at the rear muffler was causing the rumble and shake while idling.
the leak was at the weld joints along the exhaust pipe that had started to rust. this was probably making the car run a little too rich as well, but i could be wrong.
cheers!!!
mine does it too at idle, is normal. atm mine has a dump pipe like 6 inches long and is running Super rich so it sounds worse, gaps are .8. is perfect when you apply any throttle though all the way to 7000rpm
mine does it too at idle, is not dangerous. atm mine has a dump pipe like 6 inches long and is running Super rich so it sounds worse, gaps are .8. is perfect when you apply any throttle though all the way to 7000rpm
ah crap that effort to edit a post was ABSOLUTE FAIL
Edited by PaulosECR33
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
