Just got a darty new car,
not a skyline and it not turbo,
i got it free and it has no rust and is straight :thumbsup:
gonna clean it and do some skidskidskid with the mega powerful 253 blue motor putting out a neck breaking 80kw
planning to put a 308 or 350 and use it to tow the 32 and tyres to the track
https://www.sau.com.au/forums/topic/231163-new-project/
Congrats for getting off your P's
And 12th car :banana: Thats nuts. I've had my license for 7-8 years and I'm only onto my 4th lol
yeh but im gonna settle now coz out of 12cars im happiest with the r32 :P the WB ute will just be a slow restoration with the gf
https://www.sau.com.au/forums/topic/231163-new-project/#findComment-4061488
So do you skidskidskid at home sam? since you got a pad and all??? im interested in gettin in2 the sport and also got a r32 but just bought a house so wont be straight away, maybe i can come and learn at your place :P jkz
yeh maybe, sometime thinkn of organisin for lota ppl to come do skids but havnt had a chance
Edited by sidewayssam
https://www.sau.com.au/forums/topic/231163-new-project/#findComment-4062240
    • Yes. Probably, given that there is only access from the bottom end of it, go with a drill bit. Don't start too small. 7 or 8mm is probably the right size. You want something that can make a big enough hole to do some damage, but not so bit that it clashes with the steel or binds up and breaks your wrist. A slow speed is probably a good idea too. Once the rubber is destroyed, you then have to get the crush tube off the stud, which will be the whole heat/oil/cutting exercise all over again, but this time with the need to strictly avoid damaging the stud (any further than the corrosion might already have done.
    • We replaced the connector just because we could and it was still there, once we swapped the injectors around it stopped. The injectors were something I had thoughts of replacing even before I first started the engine and in hindsight I should have
    • Not too sure just yet, want to have a go at doing what I can myself, but to start with want someone to cast their eye over it tell me what needs doing to get it running and back on the road, so anyone with great overall knowledge would be ideal.
    • I personally would go with cutting out the rubber. Then deal with getting sleeve off separately. Rubber can be painful to cut, it loves to jam up cutting tools. I normally have success with drill bits, deburr bits, angle grinders, jigsaw, reciprocating saw, and never forget... fire. Obviously different tools won't work in all locations you're trying to work with, and you need to be comfortable with each. You personally may be happy slowly slicing it out with a razor blade, if you are, go for it with one too! Feel free to wait for others to weigh in also on their thoughts.
    • So ... I got everything disconnected and started dropping the frame. Three of the four mounts started to come down but the fourth one (the one with the nut that gave me all the trouble) won't budge. The inner metal sleeve stays up tight against the chassis rail although the outer part of the mount drops a bit (and can be levered quite a lot more) but it's just stretching the rubber bushing. So I reckon there's some serious corrosion inside the inner sleeve and holding it tight to the lug at the top of the bolt. Tried everything I can think of so far: penetrating oil, whacking the top of the sleeve to vibrate it and wedge a screwdriver blade in there. I also tried to turn the inner sleeve a bit by hitting it with a chisel at the bottom. It's stuck solid. What do you think about cutting the rubber with a blade so I can drop the subframe around it anyway. Then worry about getting the inner sleeve off after? Will that work? Is it gonna give me even more problems?
