Hey guys,
 I did a bit of a search and couldn't seem to spot anyone with the same problem. I have just had my Power FC put in and now when the key is turned to the accessories switch the engine light flashes at a constant flash like an indicator. When i turn the key to the ignition switch (turns on aircon fan, etc) it goes off. As for when im driving i am yet to see it at all. I am experiencing what i think is a bit of a miss while driving at constant speed but i don't get any lights when it occurs.
Any suggestions? Can i get something out of the FC hand controller that might help?
I don't have an english manual so if anyone has one id appreciate it :thumbsup:
Cheers
https://www.sau.com.au/forums/topic/231182-check-engine-light-flashing/
From Apexi PowerFC FAQ
The cars factory engine check light or exhaust temp light should NOT be on. If this is on or flashing it indicates a sensor problem. See the "Sensor Check" section on what to look for to identify the faulty or wrong sensor.
MAIN MENU, ETC, SENSOR SW / CHECK Look for any sensor names highlighted in BLACK background or any flashing sensors. Any highlighted in black indicates a problem.
hope that helps?
Did you find out if it was a sensor issue? If its the exhaust temp sensor then its nothing really to worry about, and when thats disconnected it will make the check engine light flash aswell.
Well seems to be the airtemp and watertemp... as they are the 2 items that are flashing highlighted in the PFC sensor screen. As soon as i switch it on though they show as being in use but no errors... so i don't think its a major issue.
Cheers
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
