Hey,
So far:
Koya Drift Tek rims, 17x8 front, 17x9 rear, Toyo R888 semi slicks all round.
G4 street spec coilovers all round.
Engine bay brace and under carriage bracing.
Hicas lockbar.
Lightened (as much as legally possible for street use).
What else do you recommend to improve handling? Keeping in mind i have a very very low budget and it is a daily driven street car.
Sway bars? Anti roll bars?
Thanks!
Edited by R33GTS25
I would reccomend getting rid of the g4 coilovers if you can sell them without tearing up to much coin and get some better quality coilovers tien(oz spec) bilstien etc as the G4's are a cheap chinese coilover and you will be surprised at the difference in the handling with a better quality shock and definatly go for sway bars as these will make a world of difference for the price.
Edited by dazmo
^^^ +1 Tein Super Street Damper Coilovers for maximum rubber on tarmac nearly at all times.
Camber kit set to -ve & Castor kit, Strut brace, Sway Bars all improve turn in and cornering eh?
Sway bars are anti-roll bars. I'd recommend getting them as your next step. Cheap, easy to install.
Conceivably you could also replace the bushings, but if you get polyurethane ones the ride may not be suitable for your daily driving (it depends on your definition of "harsh").
Other alignment products are also good, but as a car you track you may also want to look at the brakes. I'd probably want to look at increasing the heat capacity of the brakes, if not generating more deccelerative force, as you can drive faster for longer.
one of the most basic mods of all but probably the hardest one to get done correctly would be a good track wheel alignment, which needs to be very different from a street alignment,
reasonably cheap mod too,
if this is wrong it can effect your lap times by many seconds
Wheres a good place to do such an alignment and how you going to know if its done properly or not ?
Take it to a suspension place that does work on track cars, so not Beaurepaires or Bob Jane.
Suspension setup is not a simple "set this at X, this at Y, this at Z" kind of thing. It depends on the car itself as well as the driving style of the person controlling it, especially if they're a track n00b and don't have any setup knowledge.
You need someone with experience to get a rough setup to start off with based on what other similar cars have. They then need to be able to translate what the driver's saying is going wrong, as well as the wear patterns on the tyre, so they can fine tune it.
If you get an alignment that's bang-on perfect the first time, you're either lucky or that technician is some kind of savant (and I want his number if he's in Sydney).
You could install a Floor Brace (Middle of the car) and a Rear Strut Brace in the boot...
Save weight by getting a Carbon fibre boot lid (not sure if its legal but you can paint it the same colour as the car so ppl can't tell)
re-adjust your camber...
How wide are your tyres? Maybe go a little wider...
Brake upgrade...
Swaybars are on their way, i knew they were same thing as anti roll bars but just wanted to make 100% sure :P.
Brakes are stock except for Ferodo pads, braided lines and vented front bar to cool brakes.
Alignment will be ok for now as i dont want the tyres to wear too fast or uneven, as i said its a daily driven street car. Wont get the bushings done as i dont want to bounce around TOO much on the streets of sydney. Carbon fibre parts are too expensive for me at this time so i have to pass on that. At the track i basically rip out all the seats, rear parcel shelf, door trims, glove box/ under arm box etc.... all the easy stuff.
Im not 100% about 33's but I know 32 GTR bonnets are aluminium and are only 1 or 2kg heavier than Carbon fibre items at half the cost.
Also.. Braided brake lines.. shortening braking distances can also help quicken lap times + good fluid and pads..
Brake master cylinder stopper.. I have heard good things about these but I personally am dubious.
if you set your toe right you can get your 2 degrees or more of negative camber without chewing through tires as quick as you think, toe kills tires, camber just makes them wear uneven, they'll last a long time and you can rotate them to get maximum use
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
