Basic Mods To Improve Handling For Track?
Hey,
So far:
Koya Drift Tek rims, 17x8 front, 17x9 rear, Toyo R888 semi slicks all round.
G4 street spec coilovers all round.
Engine bay brace and under carriage bracing.
Hicas lockbar.
Lightened (as much as legally possible for street use).
What else do you recommend to improve handling? Keeping in mind i have a very very low budget and it is a daily driven street car.
Sway bars? Anti roll bars?
Thanks!
Edited by R33GTS25
negative camber.
i noticed the traction difference at the front as soon as i added 2.0 degrees (which is bugger all).
i think it's a quite worthy mod.
Edited by dmr
I would reccomend getting rid of the g4 coilovers if you can sell them without tearing up to much coin and get some better quality coilovers tien(oz spec) bilstien etc as the G4's are a cheap chinese coilover and you will be surprised at the difference in the handling with a better quality shock and definatly go for sway bars as these will make a world of difference for the price.
Edited by dazmo
^^^ +1 Tein Super Street Damper Coilovers for maximum rubber on tarmac nearly at all times.
Camber kit set to -ve & Castor kit, Strut brace, Sway Bars all improve turn in and cornering eh?
Sway bars are anti-roll bars. I'd recommend getting them as your next step. Cheap, easy to install.
Conceivably you could also replace the bushings, but if you get polyurethane ones the ride may not be suitable for your daily driving (it depends on your definition of "harsh").
Other alignment products are also good, but as a car you track you may also want to look at the brakes. I'd probably want to look at increasing the heat capacity of the brakes, if not generating more deccelerative force, as you can drive faster for longer.
one of the most basic mods of all but probably the hardest one to get done correctly would be a good track wheel alignment, which needs to be very different from a street alignment,
reasonably cheap mod too,
if this is wrong it can effect your lap times by many seconds
Wheres a good place to do such an alignment and how you going to know if its done properly or not ?
Take it to a suspension place that does work on track cars, so not Beaurepaires or Bob Jane.
Suspension setup is not a simple "set this at X, this at Y, this at Z" kind of thing. It depends on the car itself as well as the driving style of the person controlling it, especially if they're a track n00b and don't have any setup knowledge.
You need someone with experience to get a rough setup to start off with based on what other similar cars have. They then need to be able to translate what the driver's saying is going wrong, as well as the wear patterns on the tyre, so they can fine tune it.
If you get an alignment that's bang-on perfect the first time, you're either lucky or that technician is some kind of savant (and I want his number if he's in Sydney).
You could install a Floor Brace (Middle of the car) and a Rear Strut Brace in the boot...
Save weight by getting a Carbon fibre boot lid (not sure if its legal but you can paint it the same colour as the car so ppl can't tell)
re-adjust your camber...
How wide are your tyres? Maybe go a little wider...
Brake upgrade...
Swaybars are on their way, i knew they were same thing as anti roll bars but just wanted to make 100% sure :P.
Brakes are stock except for Ferodo pads, braided lines and vented front bar to cool brakes.
Alignment will be ok for now as i dont want the tyres to wear too fast or uneven, as i said its a daily driven street car. Wont get the bushings done as i dont want to bounce around TOO much on the streets of sydney. Carbon fibre parts are too expensive for me at this time so i have to pass on that. At the track i basically rip out all the seats, rear parcel shelf, door trims, glove box/ under arm box etc.... all the easy stuff.
Im not 100% about 33's but I know 32 GTR bonnets are aluminium and are only 1 or 2kg heavier than Carbon fibre items at half the cost.
Also.. Braided brake lines.. shortening braking distances can also help quicken lap times + good fluid and pads..
Brake master cylinder stopper.. I have heard good things about these but I personally am dubious.
if you set your toe right you can get your 2 degrees or more of negative camber without chewing through tires as quick as you think, toe kills tires, camber just makes them wear uneven, they'll last a long time and you can rotate them to get maximum use
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
