Just thought i would post some pics of my R33GTR circuit car. I am still in the process of building it but am starting to see some light at the end of the tunnel. Have just got the car running and am running the new engine in at the moment 40klm's so far but still plenty of work to go. Build time so far has been around 18 months. Specs are as follows.
1995 R33GTR non vspec (dont let the sticker fool you)
Interrior: 6 piont roll cage, Cobra suzuka seat, 6 point Willans harness, Seabelt seuade wheel
Suspension: Tien super street coilovers with EDFC, Whiteline front and rear sway bars, Whiteline front camber kit, Tien adjustable castor rods. Hicass will be deleted. This suspension set up will get some attention as soon as the budget permits.
Brakes are currently Brembo F50 front calipers with 355mm rotors on flaoting hats with ferrodo ds3000 pads and standard brembo rears with project mu pads.
Engine: N1 engine block, HKS step 2 2.8lt stroker crank, HKS rods, HKS step 2 2.8lt piston kit (different pin height), full Tomei metal gasket kit inc head gasket,inlet manifold,throttle body,exhaust manifold,turbo & dump pipe,
Head has been mildly ported and fitted with HKS inlet and exhaust cams 264 10.2mm & 272 10.2mm respectivly, Tomei type B valve springs and retainers, Tomei cam stud kit, ARP head stud kit, HKS cam gears, Nismo timing belt.
Hi Octane modified sump with a custom dry sump set up running a peterson 5 satge pump 3 pickups from the sump and on off the back of the head, Peterson 3 gallon oil tank, ARP main stud kit, ACL race series bearings, N1 water pump, Tomei exhaust manifolds, HKS gt2530 turbos, Hks adjustable waste gates,HKS hard piping kit, Tomei 3" dump pipes, Custom front pipe twin 3" into 4", Full 4" exhaust.
Fuel system: standard fuel pump used as a lift pump custom serge tank, Twin Bosch 044 fuel pumps running thru two -6 delivery lines and 1 -6 return line to a HKS fuel rail, Sard 700cc injectors am currently undecided on wich brand of fuel reg i will use either a Magna fuel or Turbo smart
Cooling: ARC 120mm intercooler, ARC swirl pot & Breather tank (not yet fitted), PWR custon radiator cross flow 75mm core with inbuilt water to oil oil cooler.
Drive train: Is currently running a standard 5 spd gearbox with ATS carbon twin plate clutch. This will be swapped for a Getrag 6 spd (R34 gear box) with Ats carbon twin plate clutch a one piece carbon tail shaft as soon as the engine is tuned and will also be looking at fitting a ATS 1.5way front diff as soon as the budget allows.
Electronics: Running the engine in on the standard computer injectors and afm's at the moment will be fitting a Motec M800 ecu as soon as I have enough klm's on the engine with motec boost control. Ruzic engineering (user name mountain runner) series 2 engine monitor, Ruzic engineering Race logger (in beta testing now) and will be looking at fitting a Ruzic engineering 4wd controller once the data logger is fitted so i can maximize my set up.
There is probably a heap of other stuff i have forgotten but as like nearly all race cars it will be constant and ongoing deveolpment. All work on the car apart from the roll cage and exhaust fabrication has been done by myself in my shed out the back without the help of any sponsors so has been a long hard slog and kept me poor but am starting to see some light at the end of the tunnel and is starting to make all the hard work and sacrifice worth it.
https://www.sau.com.au/forums/topic/231223-dazmos-r33gtr-build/
  • Replies 148
Risking I am running filters in all the scavage lines before the pump and also the one in the boot before the tank although the filters that peterson supply will not stop any bearing material going thru the pump if you happen to have a catastophic failure but the pumps are very resilaint and need to have some fairly large size schrapnel go thru them before it will damage them. The filter in the boot before the tank thou if much finer and will catch any bearing material (hence the size of it so as not to impeed flow) should you ever have that problem. I will be doing betwwen 500 and 1000 klm's on the engine before the ecu is fitted and in sees a dyno.
Looking great Daz !!
should be ready to rumble real soon
Will be coming for a trip up to your place this weekend sometime mate will get some k's on the thing and take you up on that drive of the R35 :banana: . The missus has the weekend off and is hasseling me to get up there and suss out your new beast for herself aswell. Will definatly sell her on the idea and get me off the hook for a purchase down the track :P
nice work mate, looks like a clean well thought out setup :P i see you have gone without abs aswell, makes the engine bay look alot cleaner without all the hardlines and unit in the corner.
Makes everything a lot easier to work on as well have been keeping my eye on Mark & Duncans build as well and there is some talk about removing the booster to get a better more consistant pedal feel. So will look into this aswell seems like just a bit of fiddling around to get the right pedal ratio as at this point I am not really considering a pedal box. This may change down the track if a better brake upgrade is done but first i need to finish it and let the bank balance recover :banana:
Great work Darren....if I didn't want my car to still do a blast down a public road this is what I'd be doing to mine :P
Interesting that you are considering putting in an R34 box....speak to Snowman (Andrew) for details but he found out the hard way that the R34 box can be fragile and that the R33 ratios are better for track use....in fact his R34 track car uses R33 running gear now.
No the R34 gearbox strength is fine - I just didn't like the ratio's in the 6 speed. For what I do the 5 speed works better.
Carry on.
very nice mate! Looking good. Will be good to have a run with you at the track when its all ready. Looks like it will shit out some good times too :down:
Hopefully it will do some good times I think the car will be more than capable just not to sure about the driver :google:. Will definatly be heading out to a few top gear and JDM meets once it is finnished. Is it your/your old mans car that is getting a rebuild at the moment in another r33 thread ?.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
