hey all,
as the subject suggests my car vibrates under breaks, im pretty sure its coming from the front right and only ever does it when under a specific breaking pressure and just before it comes to a complete stop, its generally when breaking slightly harder then normal but only slightly and if i pull up harder it doesnt do it? its got me stumped.
Ne help?
Cheers
John
u r brake rotors are warped dude take them to a shop to machine them and it will stop .u'll find it does it worse down a long hill when u aply the brakes slightly when u brake hard it wont do it as much if at all.
yeah, Ive warped my rotors a few times, cant normally feel it thought the pedal, just causes either squeaking or grinding noise from brakes.
As long as they are not too worn out, just get them machined back.
the rotors only need to be warped a fraction of a mm and the car may chake under light braking when u put more pressure on the pedal it will usualy ( but not nececery ) stop shaking , also it may not do it as much when the brakes are cold .
mmm... do you have spacers?
that'll be why if you have them, not the discs.
I've got the same problem.
I thought it was warped discs but that's not what it is.
under brakes the front end sometimes shudders really bad ??
