Hey everyone,
Ive been searching around and no one seems to make alternative shocks for the r34 gtt appart from bilstien.
I dont think Koni, monroe, KYB seem to make shocks for the r34 gtt.. Does anyone know of another manufacturer that makes shocks for the r34?
Just weighing my options and id like a shock and spring setup rather than coilovers... (I know of the sydkid group buy i wana know if there's anything else out there)
I want to lower the car 1-2inches all round
Cheers for any help guys
Adrian
https://www.sau.com.au/forums/topic/231292-r34-alternative-shocks/
bilsteins are really good shocks ..better than most of the crap out there apparently. But be warned about the group buy, the delays are long .. I paid for mine a month ago and it could still be another few weeks before I have them.
koni make shocks for the 34 gtt as i was lookin at getting them earlier. They are a standerd replacement with the adjustable struts. Try www.toperformance.com.au they r the distributers for koni. u just gota let them know if the rear has the eye or fork at the bottem.
koni, i wonder if they would also do a shock for a lower than standard replacement..
Any other options for shocks?
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
