Hi all :P
When I finally got my car out to the drags at the end of last season here with a few gremlins still bugging me - the car only managed a 13.3 @ 112mph. At the time, there were other issues anyway so I didn't bother with addressing the lack of grip part of the whole thing but now I have the others all sorted and drag season is coming again :P
The car realistically should be running at least a couple more mph next time I race but the 112mph bit should give a rough idea of the power level I am making. What tires running similar power levels are people using? I have looked around a bit and in my searchings so far on here people have been very unspecific about tires they have used to achieve times.
I am looking at Hoosier Quick Time Pro DOT 26/9.5/16s and maybe to put on stock R33 GTS25t rims at this stage. Has anyone tried these, or have any other combinations they'd recommend? What kind of improvement have you had from going from normal road tires?
https://www.sau.com.au/forums/topic/231307-what-tire-for-r33-gts25t/
MT ET Streets. 255/XX/16 on 300zx or R32 GTR wheels.
/thread
Thanks for the input :P Just to clarify, are you aware there are two different "ET Street" drag tire types from MT? One is the DOT dated bias ply "ET Streets" and then the stere are the "street legal" ET Street Radials. Given you have provided a "255/..." type measurement I could assume you could mean the 255/50/16 ET Street Radials?
Please appreciate that I want to make sure I am hearing it from someone who isn't just regurgitating what they have heard or read half paying attention somewhere along the line - I know people who have bought tires from advise given by someone just blurting out specs like that and have ended up worse off for it and would like to be sure I am getting the right thing.
Sorry mate, hahhaha
I have raced my old R33 GTS-T on them, they were borrowed from another R33 GTS-t that was doing 11's RNMENC. Actually, almost everyone I know that drag races in any street class races on them, Including the one and only 2RISMO.
The exact measurements I couldn't tell you but I'm pretty sure they are 255/50's
Here is a thread - talks about sizes, simple search. If you check out the car that is in the first post by bezerk32 Those are the exact tyres and wheels I used. There is some good discussion from a few users, sellers and drag racing whores.
Personally, I would take in what bezerk32 has to say as he has ALOT of experince in Street class R33 GTS-t drag racing.
Here is another thread with some more info on them.
Oh - and here is another thread
http://www.skylinesaustralia.com/forums/Mi...di-t141522.html
It's a group buy that WAS on offer but NO LONGER is i believe. You might find some discussion on it there too.
Gahh I clearly didn't make the search work right. The times I did it I only found things like "MickyT ET Streets" or the such. Thanks man :P
Oh, and if you need a pair, just let me know.
Cheers! Thanks, that was my initial preferred option but for some reason people warded me off them - but I trust you guys more :starwars:
Can you get them for a decent price, 2rismo? I am NZ based at the moment and they're not easy/cost effective to buy here. At the moment my best option looks like this:
http://store.summitracing.com/egnsearch.as...k=KeywordSearch
That's $484NZD for the tyres and a massive amount in shipping. Surely there's a local speed shop who'll sell them to you for $300-ish. Even low $300's each will be cheaper. Plus Summit are out of stock until the end of the month so you'd be waiting quite a while.
You can easily spend >$1kNZ on a pair of tires like that. The local shops I have spoken to don't supply them, a couple have indicated they can try and sort it out but the cost would basically be them buying from an overseas company and charging me for everything + their cut.
I've only ever seen one set of drag radials used here too, most people go the DOT slicks at around 26x10.5x16 which would be a bit more than what I would think I'd need? http://www.trademe.co.nz/Trade-Me-Motors/C...n-169832480.htm
Also, will I need to upgrade from my heavy duty single plate clutch to a twin plate for 255x50x16 MTs to not destroy the poor thing?
A good single plate is more than enough for most applications. What is power level / engine setup?
I have asked the question of my supplier about shipping to NZ for you. Will let you know the answer.
It would make sense to slot a Jim Berry single in with the tyres to save on shipping. That's what I'd do.
280kw - in his sig.
BTW Lithium, it's Tyres not Tires.
AUS > USA
280kw - in his sig. BTW Lithium, it's Tyres not Tires. AUS > USA
LOL yeah I know its tyres (its that in NZ too), I'm not always too sure about how you do things in Oz and get used to using tires on overseas forums. Wanna chup brue?
In terms of decent single plate mine has been holding on fine for ages, I don't think I'd worry about getting a clutch until I reach that point - there are plenty decent one available. The 280kw may not be the same as 280kw on the dynos you are used to, may be closer to 250kw at a guess - whatever a .82a/r GT30R running around 15psi on a stock RB25 would make normally.
2Rismo - thanks for that. Where did the reference to Greenlane speed shop come from? Do you have reason to think they stock Mickey Thompsons?
Edited by Lithium
Yeah, 250kW sounds about right. If your clutch is fine then leave it but you will find that these tyres will test it to the limit. If it's found wanting, buy a new one. Easy :P
I just googled NZ speed shops and they came up. It was a pretty dismal result though. You'd think that NZ doesn't have a speed parts industry.
Yeah, 250kW sounds about right. If your clutch is fine then leave it but you will find that these tyres will test it to the limit. If it's found wanting, buy a new one. Easy :google:
Yeah its pretty shit here for getting parts, my turbo, injectors etc had to be ordered from overseas - if I ordered them through a shop then it would have taken the same effort and amount of time but a bit more money. Not for everything of course, but its not necessarily the easiest. Being one of the more remote countries in the world with a small population basically means its not worth stocking up heavily on parts.
Clutches I *can* get pretty easily and cheaply so the way I see it, if it breaks I can decide whether to get a single or a twin plate. Thanks heaps for your help - good having people who have been there done that!
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
