depends mate entirely on what kind of job you want done and how much you want to spend. For a truly show car finish, back to metal will be required but this is going to cost mate, not sure on exact price per litre of paint but labour and paint back to metal (on the assumption no dents.rust) you will not have much change from $7,000
https://www.sau.com.au/forums/topic/231328-respray/#findComment-4062488
depends on brand of paint, the paint we use at work is one of the most exspensive on the market and we pay about $600 for a clear kit, there are cheap brands that are like $100 and PPG from memory is about $400.
USeally for a re-spray they just sand all the clear off with about a 600 grit paper then apply the colour again then clear it so you'll have a higher firm of paint but you really wouldnt be able to tell from just looking at it
https://www.sau.com.au/forums/topic/231328-respray/#findComment-4064120
yeah, the majority of the time its a case of sand the old paint coat, filling the dents, priming, painting. unless you are prepared to pay the cost of a bare metal finish (not cheap)
im keen to repaint my car at some point, just gotta decide on a colour :S
https://www.sau.com.au/forums/topic/231328-respray/#findComment-4066768
i'm in the sasme boat. I'll be painting my GTR straight away just can't decide on a colour
https://www.sau.com.au/forums/topic/231328-respray/#findComment-4068400
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
