The best idea is to take it to an auto transmission service place, the trans needs to be flushed, otherwise you will only be removing about 60% of the old fluid, alot of fluid is held in the torque converter. Having the trans flushed removes 95% of the old fluid from the system, including tranny cooler.
I have serviced an auto once, and in the end it cost me just about as much as what it would have done if I had it done by the professionals, and I couldn't get all that old fluid out.
You can sort of flush the system, but not to the extent that the service shops can do, you could proberly get around 80% of the old fluid out with a bit of mucking around. unfortunatly you will end up wasting alot of fresh trans fluid in the process.
The whole auto trans system holds 8.3L when completly empty, but if you plan to do any sort of flush you will need more fluid.
There are a few different ways you can service the trans at home, it's not that difficuilt to do.
1) Is by simply draining the fluid and topping up with new fluid, this will only remove the old fluid in the pan.
2) Is to drain the old fluid out of the trans, top up with fresh fluid, take the car for a 5 - 10 min drive to get the new fluid circulating the whole system, wait till trans cools so you don't get burnt, then drain the fluid out of the pan again. put bung back in and fill with fresh fluid, this should remove around 80% of the old fluid.
3) This service is about the best you can do at home, and requires abit more work. To do this sort of service you will need to buy an auto service kit, it should include a trans filter, and a new trans pan gasket. You will also need a clean place to work, as you don't want any dust to get into the trans, when you remove the bottom plate of the trans and replace the trans filter.
Drain the old trans fluid as above, and refill with fresh fluid, then take the car for a drive to circulate the fluid, wait till trans cools so you don't get burnt, drain fluid again. Remove trans pan, making sure no dust can get into the trans. Change the trans filter. Next remove any trace of the old cork gasket off the pan etc. Clean any sludge off the bottom of the pan with a clean paper towel, clean off any metal filings from the magnets on the bottom of the pan, once clean replace magnets to original position change gasket and put back together, making sure not to over tighten the bolts holding the pan on, or it will leak. Replace pan bung, and fill trans with fresh fluid, check trans fluid levels when warm to make sure they are correct.
hope that helps
Guest RedLineGTR
Question. Basically all the fluid in the auto trans circulates from the pan to the torque converter etc. BUt when u drain it you only get the stuff out of the pan not out of the torque converter..Yes? So basically when u put the new stuff in it will still mix with the old stuff in the torque converter. So the oil will be newer but not as good hence the old oil still in thier that gets mixed with the new stuff. IS that right??
Another way of doing it takes a bit longer and a bit more fluid but does a good job is to remove the auto trans cooler hoses and place the pressure hose in to an old tin to drain the old fluid and put the return line in a container of fresh auto trans fluid to put new fluid in to the system.
Start the engine and let it run until the fluid coming out of the pressure line is a nice red color to make sure all the old fluid is out and top up to the correct level afterward.
This makes sure the pan and torque converter are flushed.
R31man
Thanks guys... Exactly what I wanted to know...
Skyla: Great info again :D
Jetdat: You got me thinking now...
R31man: I was looking at my tranny cooler the other night thinking exactly that... Has anyone successfully performed this?
hippy: I don't think there is a "Magic Auto Fluid" ;) Castrol make a good fluid that is reccomended for Nissans, is fully synthetic, has better temperature handling, and is mega expensive... $65 for 4L !!!! So if we need more than 8 to flush it plus a bit more to spill on the floor thats around $200 worth of fluid. OUCH. Gunna call Nissan next week and get a price on Nissan MATIC D.
Might also see if I can befriend an auto technician nearby ;)
I have done it quite a few times with no problems at all. Works like a charm and is heaps easier, effective and a lot less messy, than removing the pan. You still have to change the filter, gasket etc. at the recommended interval though.
BTW Nissan Matic D isn't real cheap. I use it in my S3 R31. I got stung around $13 a litre from the local Nissan dealership. But that's in Tassie so I'm not sure if there is extra for freight etc. Castrol Transmax Z is exactly the same stuff but a lot cheaper.
R31Man
yes to all above questions.
How many litres does the auto trans take
Fully Drained = 8.3L (is that Right?)
When drained normaly without the toque converter???
As far as I know 8.3L is correct, that pretty much what I can interpret from my japanese owners hand book.
Sorry don't know how many litres is held in the pan.
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 😪 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
