Ouch man, sounds like a dodgy bloke sold it too you.... Im not sure what you can do, but if you ever need to re- register it you may be up shit creek. I woulsd say that the bloke that did it, whacked the plate on another car (therefore eliminating anothe compliance fee)... But your the ones thats going to get ****ed over in the end... I would ask the bloke, then if he isn't ay help Coppers/RTA would be in my sights.
Sumo
as long as you have the compliance papers and engineers reports etc you should be able to sort it out. contact the compliance place or place you bought it from and see if you can track down the plate... if not you might have to see if you can get one from canberra (very hard to do)... papers are usually all you need to register it though.
Guys,
I got my paper work and shit that i got with the car, RTA papers and the rest and rang up the dealer......gave him an ear full about pullin shifties....then gave me a sob story to say that he has to check the paper work.....blah blah......which they found within ten mins and then sent his apprentice to my place to mount the plate.....very interesting. :uh-huh:
Thanks everyone
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
