Well, i have finally decided and put a deposit down on an engine conversion kit for my N/A R33, I will be getting the engine from Just Jap, and with 31,000Km's on the clock, i think that i have done pretty well ;) , the only problem is now i have to wait!!!!
The half cut is still coming in from Japan and will be in Sydney in a few weeks after that, it needs to be pulled apart and freighted here :)
Anyone in WA ever done a conversion?
Also without an LSD will i be missing out on much, and with the rear hubs not being changed (from 4 stud to 5 stud) will this be an issue (my rims are 4/5 stud type rims so that doesn't really cause an issue), should i just by the rear hub assy, and brakes to keep it consistant with the front?
Thanks, pretty excited, but won't be excited until i'm behind the wheel of my car with the new engine.
Kris
https://www.sau.com.au/forums/topic/23138-na-to-turbo-conversion-the-big-move/
yes well that may be true, but back when i got my GTS i could not afford insurance. Now i can but have loans outstanding, and rather than sell my car (which i have tried and failed) i thought i might convert it, it gives me something to do, and i like my car anyway.
Guest neoGT-25
Hey all, a south-east queenslander here :)
congrats on the -t to your gts skyliner33wa :)
ummm... i have a non turbo R34 right... i want to get me a R34 GTT 1/2 cut in a few years but my friend was giving me an idea and i dont know enough about it to consider it seriously... he was saying if i got a rb30 bottem end and added a rb25det neo head that i would pretty much have a rb30det neo... is this concept right or wouldent it work??
sorry to theive your thread :)
thanks guys, well yeah i and my sisters boyfriend will be doing it, so labour will be free which is cool, i just want a standard GTST fro now, have always wanted one now i have made the move, i know that its gonna cost me alot but you only live once, plus i'm still young. I am getting the rear Hub Assy so, all i am missing out on is the LSD, i don't mind
Thanks
Kris
i was thinking of doing the same thing with my n/a but have been told by most people that its a lot easier 2 jus buy a GTST because ill have 2 change the engine, brakes gearbox blah blah blah and it will take a long time
also just wondering wat does it get insured as? a modified GTS? or a GTST? and because it wasn't originally a GTST does this mean that insurance will b higher then a GTST?
well, cause me and my sisters boyfriend will be doing it labour will be free, yeah it would be easier to buy a gtst but i can't afford it, plus i wanna do my own thing, about insurance, havn't really found that out yet, but i will tommorow, got an insurance broker i'll go thru
  • 6 months later...
Hi,
just interested to know how much it cost for the engine and parts etc, i will be looking to do the same thing in a year or so and want to know as much as possible before i go ahead with modifying my GTS..
also just a thought but for the same amount of money, is it just easier to get the same amoun tof power or more from the RB25DE?? leaving it N/A?
:rofl:
  RB20LagWagon said:
this would be a perfect oputunity to do a rb30det conversion insted, pity you have already purchased the front cut.
You should really ask these questions BEFORE putting money down.
werd.
for those talking about turbocharging an NA, and who havent yet committed funds, get yourself to the induction performance thread on this site and read about Rb30dets.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
