Hey guys. I am maxing out my stock air flow meter and the guys at Croyden say it might be faulty. There is another one sitting in the back of my car as i just brought it. Could you please tell me what color sticker or part number in on a rb25 one as i suspect this one might be a rb20. What color are the rb20det ones.
Help asap required. Cheers
https://www.sau.com.au/forums/topic/231387-rb25det-air-flow-meter/
Everything you need to know about the AFMs are on the link..
Green = Series 1
Pink = Series 2
Rb20 is the same as S1 AFM
http://paulr33.skylinesaustralia.com/diagr...ter-wiring.html
If they are maxing out best to upgrade to a Z32..
yeah thanks heaps for that guys. Much appreciated. I dont need to upgrade there is something wrong with this one i think. It is hitting 4.8 volts at stock boost. So yeah think it is shot but there is another in the car they are both green. Thanks heaps.
Oh does it matter what rb25det you have as to whether you run the series 1 or 2 AF meter. I am not sure which series the motor came out of. Is there a way of finding out?
the site tells you im sure of it
green label
rb20
rb25 series 1
pink label
rb25 series 2
you can mix and match but you have to cut wires
so if you have green label, go for an rb20 or rb25 s1 afm
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
