just bought a r33 gtr vspec series 2 and only has a catback exhaust.
What would be its potential down the 1/4 the way it is now
and what would the potential be with just 12psi boost, hiflow panel filter and a full exhaust
average driver: ?
good driver: ?
i couldnt find much info regarding this
out the box GTR Nissan quoted a 13.2 I think, so you would say around a low 13.
vspec slightly heavier but then you have an exhaust which should give you more torque and power (a little anyway) so that may counter the extra weight of the v-spec.
Obviously this would have been with a gun jap driver.
i think you could safely say with fliter and exhaust and no tune, you should hit a low to mid 13 without too much drama.
Any faster and you will need to look at a tune to get things working properly and then flat 13's, high 12's would be attainable.
Then add dollars to take off time, one you get to low 12's, high 11's, talk big dollars for each 10th of a second you want to shave
Edited by R34kid
Refer too what time will my car run thread,........ 14.0 @98mph
average driver: ?
good driver: ?
haha I thought I would be a little more genuine than sarcastic.... When I first read I thought exactly that, but then broke it down a little more and though take the average run of the mill etc.....
if he drives like my sister, erm about a week.... or worse still will dump the clutch forget she had it in reverse and take out the car staging behind..... DOH
  • 4 months later...
  • 3 weeks later...
Now with larger turbos and more power my goal is a high 11 second pass on 20inch rims. How much power is required to do this?
I ran a 12.9 sec pass with the 20in rims with the same mods in above post.
so a .3 difference.
What are your thoughts. Can this be done? And if anyone has done it would be good to know.
The bigger rims will give you a larger rolling diameter & more weight generally, thus slowing down the time gain from extra boost. For the drag strip, use the stock rims with a GOOD set of tyres & the time will be much better, & it will put less stress on the drivetrain as a whole. Stick the 20s back on for cruising bling.
  • 3 months later...
he hit high 12's while everyone was saying 14 flat ??
you did pretty good mate. im running mine tomorrow. so hopefully i do a 13 :D
We say that so you aren't tempted to be a retard and actually go to the drag strip instead of walking around telling various people what your car "would run".
It's a public service we offer here.
