Ok so my girl was driving her stagea along the other night and whilst driving along she heard a click and everything cut out (engine,brakes,power steering, stereo, head lights etc) now it wont start and we have no accessorie lights, the parkers work but no head lights interior light works and so do the hazards, i have checked every fuse and they are all fine and i am hopeless with electrics so i am stumped on this one.
Any one that can help it would be much appreciated
It is a series 1 97 model rs four stagea
https://www.sau.com.au/forums/topic/231409-hey-guys-major-issue/
Have an auto electrician look at the imobiliser, sounds like it cut in and won't turn off.
hey dude cheers for the reply nina called the immobiliser ppl and apparently they have a safety mechanism so they cant cut in??? although the light for it is not flashing any more
there is a main relay and/or fuse in pretty much every car. have a look for that. might be affecting things.
i had a look at all of them and they looked fine , it is wierd that it cut everything out though??
Do you have dash lights?
Find the ECU and give it a whiff. If it smells like its fried the board, you might be up for another ECU.
Try plugging in another ECU anyway to see if it kicks back to life.
A mate of mine had a similar problem on his Nissan, except the car wouldn't start at all. He called in an auto sparky and the cause was dodgy connectors on the positive battery terminals.
Off topic, but I noticed you live in Tamborine Mountains. I'm tatking the Stagea for it's first camping trip up there this weekend. What temperature does it get down to over night? Am I going to freeze by nuts off?
if you manage to freeze em off can i have them to hang around my mirror, seems every one els has gone the fluffy dice and i dont like trends so i think a set of fluffy testicals will be awesome.
mouldy?
I have been caught this way myself. Even if the terminals appear tight it is a good idea to undo them, clean the battery posts and inside the clamps with emery tape or sandpaper and retighten. It may not be the answer but it won't take long.
this may sound dumb but have you tried to jups start it before it happend . my mate juped his car off mine and must of jumped it backwards . brought my car back and then i went to drive and had the same prob . it killed my altinator and drained all f#%k out of the battery . it just a thought as if your battery doesnt have enough power your immobiliser wont dissarm.
Haha, thanks for the replies guys :thumbsup:
I spotted a green RS4 up Mt Tamborine. Anyone of you guys?
That is me. I live here. Stag went to coast on tilt tray today to get Mrs 66 indescretion with concrete water tank fixed.
Will be very interesting to find out what is wrong with Peterman Stag.
  • 1 month later...
My S2 has just started doing some strange things too. When idling if I give the high beams a flash everything stops for a second, motor stops, lights go out. no ignition lights. Sometimes when I apply the brakes while driving everything gives a flicker. Today I turn the key to start up and nothing happens at all. Try again a few seconds later and everything works normally. Does this sound like a bad connection on main fuse perhaps.
cheers Craig
