I've recently bought a 32 and have sometimes noticed a whiff of petrol when parked and sometimes when driving. I had a look around in the engine bay and noticed it was a bit damp and dirty around a few of the injectors. I've done a search and found it seems to be common occurance with rb20s.
My question is, is it something dangerous that needs fixing asap? Could I go through a drift/track day with it?
Any help would be appreciated
Cheers
https://www.sau.com.au/forums/topic/231436-leaky-injectors/
think about it like this, you have fuel leaking out of a pressurised source into a hot engine bay.
so a highly flameable material next to a whole heap of heat, and if it leaks a lil more and has a bit of a spray instead, and it gets on the exhaust then yeah, big trouble
if you have a car problem related to one of these
FUEL
BRAKES
SUSPENTION
then get it fixed immeditatly
https://www.sau.com.au/forums/topic/231436-leaky-injectors/#findComment-4064543
Time for some GTR injectors
No it's not. That would entail a re-tune to compensate for the higher amounts of fuel that would be delivered on each opening of the injector.
Get the injectors looked at. They may be repairable. If not, then replace them with RB20 injectors.
https://www.sau.com.au/forums/topic/231436-leaky-injectors/#findComment-4065412
Very common.
Clean the effected area to locate the exact spot of the leak. Its most likely from
- the o-ring up top
- upper insulator
- lower insulator
- the injector body itself (the plastic part where theres an indent from the injection molding
Nissan OEM seal/insulator are about $80'ish I think, though theres a link on SAU from a guy who sells them for dollars.
Iv never done it, though guess you could pressurize the FPR to simulate having some boost / load under it; proper rail pressure would assist in locating leak.
https://www.sau.com.au/forums/topic/231436-leaky-injectors/#findComment-4067376
I had an issue in my 180sx as well, was a pinched 0-ring, took the injectors out, replaced all the 0-rings and had the injectors ultrasonically cleaned while out of the car.
Turns out, my injectors where so far gone that 3 of the 4 where stock open to some degree, and the 4th was spraying all over the place. Cleaned the injectors, re-fitted them with new o-rings.
The difference was amazing, and something else that I found was the injectors being stuck open mean that fuel was leaking into the cylinder when the engine was shut off, and if left overnight would eventually soak down into the sump and foul the oil as well, so I had seriously thin oil, and fuel leaking outside of the engine.
Also, as Adam said, any track that is worth bothering about will spot the leaking injector patch and immediately turn the car around as a risk.
Thanks,
B.
https://www.sau.com.au/forums/topic/231436-leaky-injectors/#findComment-4068686
Also going to check out my O2 sensor as my fuel economy is rubbish!
You have confirmed you have leaking injectors, and then you say you have poor fuel econemy, I am going to sound a little smart-arse here, but I would put some of that poor fuel econemy to the fuelt hat is leaking out of the engine block and vanishing down the side of the block, instead of into the cylinders for combustion.
Make sense?
B.
https://www.sau.com.au/forums/topic/231436-leaky-injectors/#findComment-4069239
On the way home from work I gave the car a quick squirt down my road and I heard the injector start ticking. Popped the bonnet and there was a shitload of fuel around #3 injector. Almost dripping out.
I've stopped driving the car untill I get it fixed now :worship:
https://www.sau.com.au/forums/topic/231436-leaky-injectors/#findComment-4073392
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
