need sum help guys i done a rb25 conversion got the engine to run pulled it out and painted my car. i refitted the 25 and it just cranks over and ive got no spark or injector pulse. ive tried different cas, ecus and replaced the ignitor module. ive check continuity on all the ecu pin outs. ive check every sensor for power and earth and still not a thing any ideas? its starting to really shit me
https://www.sau.com.au/forums/topic/231437-rb25det-wont-start/
if you are getting power to the injectors and coils i'd be making sure a pin hasn't backed out of a plug somwhere. other then that you've replaced everything that could cause it. double check all the power supplies at your computer again and check if you are getting a pulse on the injector outputs.
Unplug EVERYTHING (and I mean EVERYTHING)
THEN, Plug it all back in.
Seriously, don't just do one or two plugs, do EVERY SINGLE plug.
You'll find you've left one plug out, or a relay out, or a fuse.
When you redo it, it'll all be sweet.
  • 4 weeks later...
I had the exact same symptomes as you except my car left me stranded 2 hours from home. Parked it and it wouldn't start. It would crank and crank, but not even a sputter. My MAF was working properly and I was getting fuel because I could smell it. After checking every plug, nothing got it to work. I replaced the ignitor module with a known good one, still didn't fire at all. Went to check for spark and as we were checking, for spark with 3 of the coils pulled and the other 3 on the engine, the engine tried to start with 3 cylinders firing and the one plug out was sparking too. Turned out that somehow the power was getting grounded before the coils or wasn't getting grounded at all. After inspection, I still couldn't find anything wrong with the coilpack harness, but it started up and drove all the way home without issue. Totally pissed me off mostly because there was "nothing wrong". Readjust the coilpack harness and confirm the ground loop on the rear coilpack assembly bolt. At least it's free! :(
Edited by Darius
have you checked the two basic things?
fuel and spark?
Are the injectors opening, get the special injector bulb that clips into the injector plug and crank it over, make sure the light pulses (proving that you are getting both constant power and signal to the injectors)
Check the fuel pump is actually priming the rail, undo the fuel line and turn the car onto the on position and physically watch fuel come out.
Take out a coil, with the spark plug still in it, earth the plug out and crank the car over to make sure there definately is a strong spark.
If its got fuel and spark there should be atleast a kick out of it
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
