Where's My Rev Limiter?
just bought a r32 that has been imported with a rb25 out of an r34 in it.
It doesn't have a rev limiter cause it goes al the way to 8000rpm!!
Ive put a bee r rev limiter in it, but it cant b too healthy for it cause she goes bang bang too much.
I would like the stock limiter back on cause i use it for driftin.
Does any one know where the stock limiter is located and how to connect it back up?
I always thought the standard limiter was built into the ecu. Someone probably retuned the ecu to have a higher rev limit?
A BeeR limiter will be safer on your motor than the standard one. Standard limiter cuts your fuel, your car runs lean and can damage the motor whereas the BeeR cuts the ignition, safer. With the BeeR you can choose when you want the limit to be as well which is good. Just set it to where the standard limit should be.
Correct me if I'm wrong. I'd hate to be spreading wrong information I've read off others.
Stock limiter is safer for your turbos. Bee-R will kill them very quickly. The fuel goes in and the hot turbo ignites it, causing an explosion inside your turbine. Thats what the bang bang is. Hello new turbo. Also, if its safer to cut ignition, why doesnt any manufacturer do it?
Manufacturers don't expect retards to be banging the rev limiter though...
Yes they do, thats why its there. They think we're all retarded too, and most of us are, hence why hyundai and kia are still selling cars.....
well said, Bee R apparently can also kills engines by allowing heaps of fuel into the combustion chamber at high revs, instantly vaporising, the thermal shock aint much good for the motor...... apparently.........
Manufacturers don't have a rev limiter there so you can bounce off it everyday. It's there so in the 'rare' even you're stupid enough to go that high it does LESS damage than what an over-rev would do.Go sit on your rev limiter for a while and see what happens then. Do you know what happens when you hit the factory limiter? The cylinder pressures go AWOL and can easily cause some serious engine damage.
Engines are built to revved, sure. But rev an engine's tits off day in, day out and you'll soon be driving a less reliable car. Things will wear out much quicker and problems will start developing. I drive my car with respect, sure I pump it every now and then but never do I intentionally hit the limiter or thrash the shit out of it and that's why I haven't had a problem with it.
Hyundai and Kia sell cars because their market is people who want a cheap car. Buying a crap Korean car doesn't make you retarded wtf...
i think your missing reading his post.
they engineer cars and usually everything complex for that matter to be idiot proof or retarded as you may call it to some degree in the event that someone may be stupid enough to do what you just said.
Yeah, fair enough :)
I have a re-tune computer in my 32 and my rev limiter is at 8000rpm :thumbsup:
I was thinking, instead of getting a Bee-R, for the $350 odd that it costs i might as well just get an after market ecu.
I also heard that they can kill the factory ceramic wheel turbo pretty quickly and that steel wheel turbos are better suited?
Realisictly your only guessing it doesnt have a rev limiter if you have only reved it to 8,000.
I have seen 32's rev limiters from factory set at 8,200. With an Rb25 in it it could still be after 8000.
I'm not suggesting to go see if it is after 8,000 just pointing out that it might be higher.
To solve your problem of wanting a lower rev limiter without a Bee-r =
aftermarket ecu and set it yourself
or
retune stock ecu by someone like Dr Drift and get him to set it where you want.
Bee*R = dead turbo. I wouldnt even use it on a steel jobby
Also, something to take into account. I've noticed that the factory tachometer needle can 'float'.
After installing my S-AFC (with digital rpm readout and peak hold) i noticed that the tacho needle would read higher than the car was actually revving. Say the tacho was reading 7500rpm the S-AFC would record a peak of say 6800rpm. So you may not be revving the car out as much as you think.
for a start why are you sitting on the rev limiter? Any fool who spins wheels knows to keep the revs as low as possible... harder to do, sure, but reving the living end of the motor, recipe for longevity right there. In what instance do you need to be hitting the rev limiter? If your peak power were the last 1k-2k rpm in a race car sure... in which case your engine is built for what you expect to be a set life on that spinner anyway. On a car that spends time on the roads... swapping cogs should happen before that... 25 with stock crank and cams over 6k is just wet noise. Awsome noise the last 3rd rev range I grant you but.. not something to write home about.. 6-6.5k is a cog swap.. your 7k...(7.1krpm for s1 wanktards) is your hard limit. who waits on the rev limiter to change?
Traditionally all nissan tachos read high, but it sounds like you have a remapped ECU, send me a pic from inside the ECU and I'll let you know what's involved in lowering the limiter to a more sensible setting... may be as little as $50?
Sam
  • 1 year later...
Yes. Your limiter is located under your right foot. To disconnect, lift your foot off the pedal. To connect, put your foot back down on the pedal.
 Share
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
