What makes you say that?
Look right next to where the dude is standing next to the car.
Can you see the profile of the bonnet is smeared/blurred?
I think its a chop as well actually...
How does that work? Yeh I want to sponsor your car so I get more buisness.... Oh wait, but make sure my company logo doesn't appear in any newspapers, tv shows or websites ok! I don't want anyone to know about it!
true point, it hard to tell i can see where u see the smear...i think the front bar near where the cooler sits looking odd 2...but overall it a good concept of the r35gtr in a blitz drift outfit!
Actually the bit that looks more chopped is the Top Secret logo on the front bar.
And having Nomiken in somehting other then an R34 would be weird. It would actually look like someone was driving the car!
I was flipping through an older Autosalon Magazine when they went to Tokyo Autosalon..
And guess what?.. there is a Blitz R35 that looks stageringly like that. A couple of the stickers are in different places but on the whole it looks like someone has chopped that photo to make it look like the real thing..
So It may not be as far fetched as it looks
Yes we know there is a real Blitz R35. I've seen it in the flesh. It's not got that body kit on it though.
  • 1 month later...
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
