Hi Everyone,
I have had my Skyline (R33) at the back of my girlfriend's house for the past six months. Driving it occassionally, and keeping the battery charged through the use of an automatic battery charger (Projecta 4300 I think), which charges then maintains. Wanted to move the Skyline today, went out and battery was flat (this is a 12 month old battery BTW). So I went to stick the charger on it for a while, and the charger showed power, but no connection for charging (battery is in the boot, and I connect the charger positive to the battery terminal +, and charger earth to where the ground wire meets the chasis). So then I try and connect the charger directly to the battery terminals - still no connection, but power is going through the charger (power light on). I then try and connect the charger to the jump start terminals in the engine bay - still no good! So I assume the charger is buggered. Take the charger out and plug it into my old MQ Patrol - all lights up and starts charging the Patrol??
What am I missing? Is there a fuse that is responsible? Is the battery that buggered it won't charge even when connected directly?? Any help would be muchly appreciated....
Thanks!
Peter
https://www.sau.com.au/forums/topic/231496-battery-charger-not-charging/
ahh ok as said try and charge it overnight on battery posts,if still no good mayb try jump starting it....if that dont work the battery must be buggered if ya really need it to turn it on u tried push starting it if its manual of course! u should take it to any mechanic to test the battery...
Edited by rgr34
if the battery is D E A D, it won't ever start on a push-start, because the ECU needs power to set everything up and control the engine.
y dont you connect another cars battery to it to see if the car turns over at all, that will tell you if the car still works and that the problem probably isnt in the car.
then check to see that there is enough liquid in the battery (dont forget a car sitting around with the windows closed all the time and having the battery in the boot can get as hot as the rest of the car especially if the rear speakers on the partition shelf have been taken out to put child restraints in for compliance) because it is likely that it may have just evaporated out. Since the battery is in the boot it means the battery is also clean and if the battery is one of those transparent ones to see where the water level is you may bee thinking that the battery is full of water when infact it is completely dry so take the battery out to check the water level
then check that the charger is pushing atleast 13volts of current. even if it is pushing 12volts get a new charger. Most 12volt chargers are pushing about 14volts out to charge a battery
other than that i dont know what it could be, mabey pulled out some wires or something....
yeah take it to a mate who has a battery tester
if the level of liquid is fine, it either means the plates inside the battery have started to wear, or the acid solution inside the battery is too weak
if youre ghetto, you can just drain the battery, refill with the acid solution and see how you go from there
or you could buy a new battery with higher CCA thats the same size
= less stress on the battery
Thanks for the replies!
Took the battery out and checked the water levels - all good. Stuck the charger on, still nothing....the battery has one of those little circles you look through with a legend next to it - green = OK; red = water low; black = ! (return to shop)....mine is black so I think it's stuffed. Well at least it's only 12 months old, and has a warranty of 3 years.....I'll take it back tommorrow....
Cheers,
Peter
Thanks for the help!
Took it back and they connected it to a big ass battery tester and charger, which then printed me out a little receipt saying "Warranty invalid, extremely discharged, user abuse." I saw the voltage of the battery on the screen - 2.1V - which is pretty low!
BUT, they are following it up for me with the company that makes the batteries, as they said they will sometimes come to the warranty party...so I'll see what happens...
I must have a continuos small discharge somewhere in my car, as from what I understand, large discharges such as amps will flatten batteries, but small continuos discharges will really kill them over the long run....wonder what it could be?
Pete
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
