Had a close one today
Was heading from Beenleigh to Logan, heading up the big hill just after you leave Beenleigh and I was giving a Late moded Holden Ute (all dressed up) a run.
As you reach the top of the hill it kinks to the right then left and the 2 lanes merge in to one just as you go over the top. I took the Ute on the outside lane and hit the top of the hill at around 120, as I new the road,
If any knows this road you will know what I mean about the top of the hill,
I backed of early as it is very deceptive due to the camber.
As it was, I was a little late in the judgment of my speed I was bordering of 4 wheel drift (that shredding noise) and needing to bring the car back to the left. Which I managed with a heart flutter.
The problem was that the Ute driver had backed of later than me and was now almost fully side way's coming off the camber and was heading straight for my rear right. I could see his front end in my side mirror and his backend in the my rear mirror. I had no choice but hit the gas again and watch him fish tail and regain it,
I was lucky that
1.I had the grunt to get moving again as I was now heading downhill again and
2. I was in a Skyline.
I swear any other car and I would have lost it and he would have hit me.
I have pushed many cars around this section of road in my years and normally on my own and using both lanes. I also know 2 people who have written there cars off on the "Hill"
We caught up windows down a few lights ahead and he looked white as a ghost and stuttered that he thought he was ****ed.
I nodded my head in agreement I thought we both were.
Feels good to be alive.
https://www.sau.com.au/forums/topic/2315-had-a-close-one-today/
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
