:O
nothing worst then being disappointed with a tune/dyno.
does the stk boost gauge read +7? coz thats 14 psi. if you dont have a tune or remap etc you shouldnt be running 14psi, not sure what stk setting is for 260s it wont be 14 psi tho.
:O
Stock boost guage reads 7..... i only picked this car up a few weeks ago.... so who knows whats been done to it
The standard boost gauge reads in mm/Hg, 7 is around 14psi.
12psi is standard for an rb26 but there is a small restrictor in the line to the standard boost controller. If you remove that it increases the boost to a nice stable 14psi. Nissan were kind enough to mark the location of the restrictor with a yellow band on the vacuum hose - so if you find the yellow band and no restrictor that is why you are running 14psi....
ok. so my EBC is plumbed into the FPR, and car is still running stock solenoid and controller etc. So basically its just a digital boost gauge right now...
The peak reading was 18.8PSI... which scares me..... why would it be this high? especially with that restrictor still in place? or boost cut on the computer?
Did Autech remap the ECU to allow more boost?
Do i have a stuck wastegate?
Could first owner in japan have changed the turbos?
What is a safe pressure for a stock RB26? with ceramic turbos?
car goes in for a tune tomorrow morning, so im trying to dig up as much information as i can!
i'm lost well and truly now.
Edited by BIT SUS
Think i found why the car is running 18 Psi....
Had a mate look over the car and took him for a spin.
He said its gotta have hi-flowed turbos and maybe hi flowed injectors, cos it goes harder than any stock GTR he's been in.
Ahem.
Does this mean the ECU has some serious tune and the boost restrictor has been removed?
umm no not necessarily, its possible just running 19psi instead of 14 makes the difference. If its running that high you should get the turbos checked out, and your tune (probably has a tuned computer of some sort like you said). It wont run 19psi with the standard system, so "something" has been done to it.
hi mate I'm not sure, would have to trace all the lines properly...the way I posted above is the way I did it which is similar. You need to keep the lines as short as possible to minimise spiking
I just checked out the computer, its stock, not a power FC or anything, so i assume its had some tuning.
Someone said that the stock wastegates only hold 14psi, unless fitted with a stiffer wastegate spring?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
