i'm trying to remove the tail lights from my 32 to get the water out of them, but i hit an obstacle fairly early on. how do you get these things out? i only managed to get one out by very lightly unscrewing it but that doesn't seem to be working on the others ;) thanks!
https://www.sau.com.au/forums/topic/231539-how-the-f-do-you-get-these-out/
yah, they're bitches... turn once to 'unlock' it, then pull... Once it is free spinning, that means it's unlocked, no amount of anti-clockwise force will help you...
Very easy to break too... so careful on the pull...
LOL! Yep the good old plastic screw...
As you unscrew them, you might need a very thin / fine filer or flat head screw driver to help hinge it out as your unscrewing it.
See how you go.
don't worry too much, you can get replacements from repco. if you can't get it out without damaging it, just cut it off with a pair of side cutters are replace it
orly ???
hahah i would have replace3d them ages ago if i new that hahahaha
best bet if you can get to the back of them is simply apply force to the side of the part you cant see ... engages the thred on teh screw more to allow them to be unscrewed with a driver - also dont put any force down on the screwdriver as you try to undo them
there was much bloodshed, sweat and profanity, but i got them all out. in my defence, i'm not a complete noob. i just wondered if there was actually some awesome way to do it that i wasn't aware of. sadly not.
wedge a very thin nail file or pin in the smaller circle which seperates the screw and the casing then force it up as you unscrew
...engages the thred on teh screw more to allow them to be unscrewed with a driver - also dont put any force down on the screwdriver as you try to undo them
^^ 1000%
Though most the time you cant get to it from underneath, so use a feeler gauge, or small screw driver to put some load on the spliced bit, just enough force to get the thread to grip again.
Worst case do Bluey33's method, but that will most likely mark the plastic.
And yah, you can get replacements from anywhere... getting the exact shade of grey can take some searching though.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
