yes, another thread about poor results. i think it is the tuner? but ill see what you guys think
the mods are:
HKS GT-RS turbo
Power Fc
ACVR ebc
fmic
apexi pod
3.5inch cat back
3inch dump/front
xforce hiflow cat...also have bashed out stock cat, cant really feel a difference between the 2
BOSCH 040 fuel pump
Z32 AFM
Nismo 740cc injectors
with these mods i was expecting bout 350hp. but no
lol some of the stuff below may be a lil irrelevant, but i thought you guys might want to know the full story.
so i got my car tuned a few weeks back. got crap results at 300rwhp @ 1bar,
so the tuner reckons whenever put sets the car more than 1 bar the car starts knocking.
there is the ocasional misfiring too, but nothing major. so i thought it's ok for now
but the knock readings show on the pfc were hell high on normal driving, barely boosting and it reads 50+, and engine light comes on sometimes too,
so i took it back and he reckons he just needs to change the timing abit. and he does that.
all this time my boost gauge shows it's hitting 1.1-1.3bar, but i think it's because it's cold and has nothing to do with the ebc
ok so the car is still knocking. and fuel economy is shithouse. 260k's out of the first tank...my rear bumper is all black lol
so retune is done free of charge.
but the car still knocks and this time it's only making 290hp? @1bar again.
now fuel economy is now better but still not good. i got 320km's out of a tank..still a bit rich as i still get a black rear bumper after 2 days lol
and my boost gauge and ebc still reads the car is hitting 1.2bar, but again it may just be becasue of the cold weather
the knocking is still there, but only when the car is cold and for the first 5mins of driving, sometimes so high the engine light flashes. and im not boosting either
but when the car is warm and i give it shit it doesnt knock at all lol, stays under 30
tuner doesnt know what is causing the knocking. comp and leak down test has been done and it's fine.
What do you guys think it is?
im thinking of bashing out the xforce cat and put that in as it's 3inch and getting split dump and front....if thats gonna make a difference
and also splitfires for the misfiring problem
should i go back to the same tuner ? been there 3 times and he still cant find the problem..he says it's the car...but i think it may be him lol
here's the dyno sheet for the first tune. i dont think it has changed much.
do u guys reckon it's the tune? or do i need to change some part?
oh and my bov is very quiet for some reason, might quieter running at 1.2bar than at 0.8bar lol
also boost doesnt come on that early as some say about the gtrs, does that have anything to do with the tune?
cheers
Edited by ztuned
At 1bar peak boost pressure that seems about right for 300hp as thats around 230ish kw. However on 1.3-1.4bar you should be seeing around 330-360hp. Now wether its breaking down in spark at higher boost levels and not making more power could be the reason.
Does it missfire up high when it hits over 1 bar driving at night on full load?
i've only had it missfire on my twice...and it goes away once i lift the throttle up. and both times were at full throttle around 5000rpm
i think the missfiring issues should be alright after new splitfires, spark plugs have been changed too.
im more concerned bout why it knocks atm
and sorry this is the only dyno graph i have, dont know what that bottom curve is lol
Edited by ztuned
First and foremost...i have been in the exact same situation...my rb20 with hks2535 started off making [email protected] was piss weak...everything seemed fine with the engine at that point...compression was good and everything else was healthy...
Turns out my Xforce cat was a restrictive POS and was the biggest restriction in the whole system...i bit the bullet and shelled out $300+ for a MetalCat and went in for a retune...instantly we were able to dial in more timing and ended up with 215rwkw@16psi...
I went a step further and installed a catch can...which might have helped to catch some oil vapour which can lead to detonation...and i also invested in a set of new coils...another tuning session later and power went up to [email protected] wanted to dial in 22psi but was told not to push my luck...lolz...
Now take what you will from this...i know alot of skeptics who said that a catch can and coils wouldn't give a gain...but its all in the tune...allowing more ignition timing to be dialled in will in turn make more power...
I will however guarantee that the xforce cat is playing a part in your dismal results...i was using an xforce cat too...bin that POS and see if you can address other restrictions in your system...good luck...
1. AFR graph, if you dont have it... makes everything impossible to tell
2. Not a disappointing result at all for 1bar, sounds about right. I think you've got higher hopes than you should have as that result for that boost is pretty much on the money
3. Before you bash the cat, just drop the exhaust from before the cat. Simple and easy to answer that
4. I think you might need to see someone else
Just drop the exhaust off before the cat and do a run, then fit the cat do another run and compare the two result with this one.
Also sounds like your coils are breaking down, so make sure you get the Splitfires ASAP, and gap the plugs to 0.8mm
Here is my graph to compare to: The graph shows exactly what a shit cat can do to the overall power. Red line was using the original "hi flowing cat", blue line showing what happened with the "better" flowing cat ;)
18psi
Tomei Poncams
Head porting
Std bottom end
3" turbo-back exhaust
icic, knew the cat was shit, didnt know it could make that much difference like shown on Al's graph.
will invest in a new cat, is it worth it getting a 3.5inch split dump/front ?
new coils are definitely on the list, but is the catch can really necessary?
ne1 more ideas on the knocking? just a shit tune lol?
cheers
Edited by ztuned
change the coils and the cat then take it back for another tune, i think you will find the knocking will drop. with out the AFR's it is hard to tell, the other thing to change is your fuel filter is this hasn't been changed it a while it could be blocked
More boost! people run 14psi through they're standard turbo's. And given that you got restrictive standard manifolds that increase boost pressure but drop airflow you could run 20psi+ without worrying anything
Your bad fuel economy is due to your injectors, they're stupidly big for that amount of power. Its not going to change unless you change your injectors, 480cc s15 injectors would be much better for the application.
High knock levels at 1 bar is a bit weird, you haven't got an exhaust restriction to cause back pressure so it would have to be ignition timing. maybe your tuner needs to advance the ignition timing to safely increase boost levels.
I disagree with almost everything you just posted.
You started out ok with your third point, but then went off track again.
Bigger injectors don't always equate to using more fuel. They allow more head room. I'd suggest another tuner after all you've been through, if he keeps sending you away with your car knocking like that i'd be hitting him up for 7k for a rebuild pretty soon.
My fuel economy is fine with 800cc injectors provided I don't constantly lean too hard on the throttle. Mr33 is 100% correct in saying bigger injectors just allow for more headroom.
ztuned the power at 14psi seems pretty spot on, basically exactly what i made with it. with regard to the knocking get the mechanic to check your Crank Angle Sensor. inside it you should have these teeth which bight on with your cam. if these teeth are worn out you can expect to see your timing go all over the place. I had this problem and tuned it 2 times before one guy figured it out and all was good from then.
Mine on 14psi is 233rwkw
When I even got my hi-flow turbo on ages ago, the cat was the most restrictive thing I had...simple fix and a couple hundred later all good.
And now with the gtrs its still good!
Id also suggest seeing another tuner/shop.
Well worth getting another tuner to give it a quick run and check the tune out before changing anything major. If its running rich and knocking then the tune sounds pretty poor I just had mine looked at since I had similar issues and they got another 20kw out of it with a better A/F ratio and no knocking.
    • Thanks! Will get it looked at before winter 🥶 other than that she's a mint ride love it aye
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
