I live in the bahamas and we have a relatively active drag racing seen here in Nassau, and unfortunately we go through alot of rb25det motors, it not uncommon to see 400 whp skylines,.
recently though there has be a shortage of rb25det motors and when i blew 3 pistons a month back i decided to rebuild mine, i should mention that there are no proper shop here to blue print the motor so we just took it down replaced the pistons, retorqued the motor and dropped it back in.
now i have a knock on start up, it last for about 2 seconds and then the motor runs fine, we have determined that the knock is a result of clearance issues, i have trashed the car around at 12 psi without any problems but want to increase the boost to 20 psi, just want to know if you well advised experts think its going to be a problem or will the knock get worse.
https://www.sau.com.au/forums/topic/231581-knock-on-start-up/
If it goes away once the its been running for a bit i would say its a bit of piston slap, which is when the piston shifts slightly in the bore. By the sounds of it anyway. Did you measure/hone the bore or did you just slap pistons in it and throw it back together ?
Minor piston slap goes away as the motor gets hot and piston size increases slightly.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
