some very late model 2005s i have seen with the projectors but most do not. they also have different tail lights with the newer one being more 3D. The front bar is also a little different also on the 06
Hi Guys,
I was just wondering what the main difference is between 2005 and 2006 v35s? do they both have projectors for the HIDs?
Thanks
  • 4 weeks later...
not sure about JDM specs but for the Infiniti G in America (where i'm from) the V35 breaks down as follows:
2003-2004: Old Interior/gauges, Reflector Headlamps, Old Tail lights, Brembo brakes + 18" wheels on 6MT&Sport model
2005: New Interior/gauges, 19" forged wheels on 6MT&Sport models, no Brembos, Reflector headlamps from 03-04, Old taillights from 03-04
2006-2007: New Interior/gauges from 05, 19" forged wheels on 6MT&Sport models from 05, no Brembos from 05, Projector Headlamps, New taillights with external trunk release button
and for the 2007-2008 models:
2007 Sedan: Became new G35 sedan (equivalent to JDM V36 4dr 350GT)
2008 Coupe: Became G37coupe (equivalent to JDM V36 coupe 370GT)
hope this helps :laugh:
  • 4 weeks later...
USDM-V35 is spot on. I imported a 11/05 V35. It had the factory 19" Alloys for the 06 spec.
The 06 has slightly different tail lights- a little sharper tapored and has the external boot release.
The front of the 06 I could not pick the difference. Though dealer mentioned headlights--Maybe difference between "Projector/Reflector" headlights.
My Interior trim is exactly the same as the 06. which was a hugh bonus.
Hi Guys,
Thanks
Question, the VQ35DE in 03 Coupe is the same one as the one in a 06 model in terms of kW & Nm?
I know Infiniti G35 05 models got the rev-up engine as did the 350z.
I believe it's the same with the V35
03-04 206kW
05-06 212kW (rev up)
06+ 222kW
or thereabouts.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
