jsut thought would throw this sucker up
our rb26/30 s15 is now alive and off to dyno
check out the video here --- >
correct me if im wrong, but i think this may be the first in australia (30/26 in s15) and will be the first street registered possibly in world ???
last crack she made 493hp with the std 26 on our dyno day on the haltech base map with just enough fuel up top to compensate (no timing or anything touched yet)
will keep everyone posted after dyno and run in
most of it has been covered on these forums comprehensively, but if anyone wants to know any tech questions about the build feel free to ask :cool:
Edited by EastCoastCustoms
https://www.sau.com.au/forums/topic/231616-ecc-rb3026-s15/
Hitman in NSW tuned (only tuned) one about 18 months ago for a mate of mine (rb26/30 + T51R) also street registered in WA... Sorry :D
I assume you guys ran into height issues also fitting it under the hood of an S15???
PS> Great work, its the ultimate car when you think about how good the S15 chassis really is, Congrats... :banana:
https://www.sau.com.au/forums/topic/231616-ecc-rb3026-s15/#findComment-4067400
Hitman in NSW tuned (only tuned) one about 18 months ago for a mate of mine (rb26/30 + T51R) also street registered in WA... Sorry ;)
PS> Great work, its the ultimate car when you think about how good the S15 chassis really is, Congrats... :)
im fairly sure there has been a few done.. and some were quite a while ago
https://www.sau.com.au/forums/topic/231616-ecc-rb3026-s15/#findComment-4072278
PS> Great work, its the ultimate car when you think about how good the S15 chassis really is, Congrats... :D
The s15s are a good chassis with the sr, with the added weight of an rb30 block not going to be good for much other then drag and bragging rights
https://www.sau.com.au/forums/topic/231616-ecc-rb3026-s15/#findComment-4077750
I didnt say the one i was refering too was the first, just saying theres was not the first road registered... :banana:
And whats wrong with that... :blink:
Is there anything else one should care about when building a car??? :P
https://www.sau.com.au/forums/topic/231616-ecc-rb3026-s15/#findComment-4085591
i know that.. i was simply saying im quite sure there is a fair bloody few of them around and some have been around since quite a few years ago!
Cool Bananas :(
Looks good guys. You know I want to see it on the track :laugh:
I want to see massive 100m skids... ;)
https://www.sau.com.au/forums/topic/231616-ecc-rb3026-s15/#findComment-4088298
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
