Model:r32 gtr, 1989
Milage:2000 km since rebuild.
Transmission:manual
Colour:black
Complied?yes
RWC supplied?yes
Currently registered?yes
Price:$20,000
Contact:pm or 0401 631 325
Comments / Modifications:listed below
Images:below
Engine has been built by CHASERS MOTORSPORT, 265.9kw on safe tune for torque not outright horse power.
Suspesion built and tuned by TURTRACK SUSPENSION
Sad to see it go but i have too many toys and the GTR must leave to a better home, one where it will be driven more.
ENGINE:
r33 gtr crank
standard rods/pistons
N1 oil pump
N1 water pump
port matched inlet and exhaust
trust oil filter relocation and oil cooler
garret 2530 turbo's
xforce dump pipes
unknown front pipe
apexi exahust from cat back
metali hight flow cat
apexi pod filters
os giken twin plate clutch
spool cam gears
power fc computer
eboost boost controler
50mm alloy radiator
650cc injectors
040 fuel pump
SUSPENSION:
revalved bilsteins, height adjustable.
eibach race coils, 5kg front, 4 kg rear
tien caster rods
noltec front upper arms
hicas lock bar
drift project rear upper arms
front and rear sway bars, adjustable
pinapples
front and rear strut brace
BRAKES:
r33 front brembo's
front pagid blue pads
dba 5000 front rotors
nismo braided lines alround
project mu rear pads
dba 4000 rear rotors
brake master stopper
ABS REMOVED
WHEELS:
nismo lm gt4 17 by 9.5
falken azenis rt615 semi slick 255/17/40 alround
INTERIOR:
willans 4 point harness
4wd controller.
turbo timer
eboost 3 settings.
https://www.sau.com.au/forums/topic/231619-r32-gtr-melbourne/
for some reason pics wont work and i cant upload any, will get it sorted soon.
the car is on car sales if you want some pics.
carsales.com.au
LOL! were you meant to give the direct link to your ad or just a link to carsales homepage? :wave:
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
