Tools needed:
- Rubber Mallet
- Pliers
- Sockets (22mm and 12mm)
- breaker bar may be required
- Hand cleaner (trust me here!)
- Brake Cleaner
- Flat head screw driver
Firstly jack the car up and remove the rims
Remove break pad wire at back of caliper. Surprisingly this can be tough. Might need a bit of plier action!
Tap out pad pins from behind the caliper with mallet.
This will then allow the Pads to be removed via the top of the caliper.
With the pads removed, now unscrew the 2 bolts holding the brake line bracket in place.
Then (here you might need a breaker bar) undo the two 22mm bolts that hold the caliper on.
The caliper should now be loose and you can remove it. I found a bucket around the same height that I could rest it on. This saves having to remove the brake lines.
With the caliper off, the rotor should come loose on its own. Might need a hammer with the mallet or just screw in a bolt as shown below:
This is the comparison between the old and new rotor. Nice!
While the rotor is off, this is a good opportunity to use rust converter on the hub section. This should help the rotor come off cleaner next time too for machining or replacement.
Put the new rotor on and screw in 2 of the wheel nuts to hold it in place.
Reverse the above process to get the caliper back on.
Any questions feel free to PM me.
  • 1 year later...
  • 1 year later...
  • 2 months later...
  • 1 month later...
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
