R34 Gtt Front Rotor And Pad Replacement
Nice, let me know how you find the 98 tune -
Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
By PotatoCake · Posted
Ah, should have been clearer. Currently has a flex sensor installed all good to go. like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho… -
Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
The suspense is killing me lol. Are you going to buy a flex sensor, then add the 98 tune to your current tune? It sounds like your just going to delete the current tune and re-tune the car on 98 =/ If you've only known your car on e85, I don't think it will be long before you install the flex sensor and go back to running e85 when its available lol.
