hey i have a r32gtst pretty much stock except it has 3 1/2" pipe.. b.o.v .. bleed valve..standard airbox.. nd standard intercooler.. i have been running it on 15 psi for the last 6 months and had not troubles other then replaced the clutch .. and i dont go easy on the throttle either. :banana: ... and it seems to be loving it :D .. no pinging,spiking ect.. so what is a safe setting to set boost at on a stock blacktop rb20 that is a daily driver...
define safe...
higher boost will just lower the life of the engine...
so technically you could run 20psi if you wanted but the engine wont last all that long...
when i had my 31 GTSX with a black tp rb20 i ran a stock S2 R33 turbo and a Apexi SAFC, 3" exhaust, FMIC, 440cc injectors and she ran 14psi all day every day for 3 years with no troubles...
thing to remember is the stock turbos are not doing much past 12-13psi, just pushing hot air as they run out of puff...
i should mention that the reason my GTSX had a black top in it was because i blew the arse out of the red top that was originally in there...
the vac hose came off the wastegate mid skid and she went super sonic and BANG...
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
