Problem - car is breaking down / missing above 4500, 5000 ish under load.
Engine - RB24DET, GT3076r, Power FC.
What i found initially - water in the valley with coilpacks (not good!)
What we did to try and fix the problem:
- soaked up all the water.
- sprayed a bit of rp7 on coil packs as they didn't appear to be that wet.
- changed 6 x spark plugs all round.
went out and tested and still had same problems.
so we:
- changed 6 x coilpacks
- went out test with normal boost of about 22psi and low boost of 1 bar.
still had same problems, exactly the same symptoms.
we then:
- checked timing and swapped CAS
went out again, still had same problems...
People that were on the sidelines said that sometimes it seemed to clear up a little bit, and then be back worse than ever.
My thoughts:
- electrical / wiring problem.
It hasn't ever had symptoms like this before even with the coilpacks (standard) / spark plugs (BCPR6ES gapped 0.7 - changed after every track meet). The igniter is securely fixed, and if it was this my thoughts are that it would be a more constant missing (it is not present on free revving the engine).
Can anyone shed some light / help brainstorm?
cheers
-Matt
https://www.sau.com.au/forums/topic/231641-help-diagnose-the-problem/
First you have to find out if it is electrical or fuel!
Can you isolate the miss to one cylinder [hard when it doesn't happen 'off load']. Can you swap coil loom?
How's the fuel pump, filter, fpr, injectors? If it only happens under load [and you've swapped out the plugs and coils] then could be fuel.
Oh, and what was the water from, washing? If its coolant, head gasket or some such for sure!
water was from the vented bonnet... good to keep heat out, but crap for wet weather...
i'm going to have a closer look tomorrow, paying special attention to the wiring - coil loom / to the injectors / AFM... will also check all the vacuum hoses - if all goes well i'll start it up again to check it idles fine, but this wont tell me anything until i get it on the dyno to get some load/boost into it. Once on the dyno will try to isolate to a cylinder...
...so if you can just throwing things out there for me to check that'd be great
thanks again
-Matt
what i found: the O2 sensor plug/connector had melted and was disconnected... could this be a problem?
other things i did to try and fix problem:
-tightened plug to ecu (it was not loose though)
-checked connectors on coilpacks, injecotrs, igniter, AFM - all appeared in working order
-change oil/oil filter/fuel filter (general maintenance)
-checked vaccum hoses/connections - all appeared ok
-check cooler piping (possible leak on boost??) - all sealed and tight
any other things? it's been suggested it may be an 'earthing' problem - can anyone specify what earth's in specific (ie where are they on the loom)
the car idles / rev's perfectly, i haven't had it on the dyno yet so i can't get it onto load/boost...
ANY OTHER IDEAS???
many thanks
-Matt
02's wont be used when the car is under load so discount that idea, howver is the plug was shorting out, this wont be good for the ECU - so confirm that
theres a known misfire bug with BNR32 and PFC users, its in the FAQ, have a read of that it might give you some ideas on where to look
    • Hey everyone, just wanted to let you know about an app I use to track the modifications, repairs, servicing etc I do to my R33 GTR. You might like to use it as well. I'm biased because my son just wrote and released it! But I think you might find it useful to... https://trackmymods.com
    • Hey everyone, been on here for a while, but never introduced myself before. 1st import was a R32 GTS Type M, then R33 GTS, now R33 GTR - each one sold to help pay for the next one. Over the years my son has seen me modify and do changes to my imports and was one of the reasons for him to build an app for car enthusiasts like us. (He can only afford a 2007 Honda at the moment, but he'll get there!) Anyway, bit of a proud Dad moment as he's released an app that I use and you all might like to as well. https://trackmymods.com
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
