Make: 1986 holden vl turbo berlina
Model:
Milage:
Transmission: 5 speed
Colour: light blue/green
RWC supplied? no
Currently registered? no
Price:12k firm
Contact: 0412285096
Comments / Modifications:
rebuilt block
new dizzy
new spark plugs and leeds
new crank angle sensor
new coil
new belts
vlt lsd 3.45 gears
sss low king springs
3inch mandral bent exhaust off the turbo with high flow cat
5 speed box
1100kg ceramic 5puk clutch
gtr lightened flywheel
battery relocated to the boot
new starter motor
ss high mount mainfold
600hp turbo
38mm external waste gate
pod filter
na runners with a polished nizpro plenum
xf throttle body
gtr injectors (440cc)
adjustable fuel pressure reg (with guage)
walbro 320lph external fuel pump
oil catch can
hybrid gt spec intercooler with 3inch polished piping
turbo smart mega sonic blow off valve
shaved head
acid dipped head
A.R.P head stud kit
roller master fully adjustable cam gear
new inlet and exhaust valves
heavy duty valve springs
cometic triple layer head gasket
wade 1147c cam (very very lumpy)
microtech lt12s computer
new steering wheel
boost guage
e-boost and turbo timer (not hooked up yet)
ive spent over $20,000 on this car!
everything i have mentioned has travelled less then 100km and has had 3 dyno runs..
its tuned to 312rwhp at 12psi but the car made 455rwhp at full boost!
  • 2 months later...
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
