My bunky, Ford Meteor, has to last me until the banks get their act together and finance me! In the mean time I want to get a few things ixed on the bunky. The main thing I'm stuck with is, my driver's side window is broken (the lever that holds the glass in place) who would I contact to fix it? I knwo this sounds like a stupid question but I've asked several people, and no one knows!!
https://www.sau.com.au/forums/topic/231729-window-fixing/
Just call around some wreckers, I reckon you could get a whole working door for $50-$100... paint probably won't be the same, but its quick and easy & cheap :wave:
but then it won't be the gherkin Tris?
it'll be like....the Gherkin with the tomato door :(
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4072409
k so this probably wont help that much but most of the time with wonders like the gerkin best bet is a little diy action and a visits to your local wreckers
ive fixed afew window winders (mostly on mates comos) and most of the time a little elbow grease can fix it
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4075236
whats actually wrong with it? the lever is missing? or it doesnt wind up and down?
If the levers missing just get one from a wrecker easy as.
If it wont wind up and down then get the window mech from the wreckers.
Take off the door trim theres like 3 bolts? or so that hold it in place with the glass in a channel, take the mek out replace it with the new one, reseat the glass, done.
Its really not a difficult process, if you can get someone on here to help you out, better half of 2 hours.
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4076185
Spark plug in the fuel tank??
Take it to a mechanic, we do shit like that more often then you'd think. Us mechanics are pretty useful!!
SPark plug? wtf? lol I'm talking about the window!!!
Yea... its not hard. You're like playing with cars. DIY Mel :(
If not... I have a sledge hammer you can borrow :D
yes plskthanks
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4076492
all you need is someone with a little bit of mechanical knowledge to fix the window regulator. Its not exactly brain surgery. I pretty sure anyone could do it. :D
umm no the lever is snapped not stuck
1. the lever is snapped
2. we masde it so it can't wind up and down so that teh glass doesn't smash
3. obviously I've taken off the door trim, how else would I know the lever has snapped??
Ok so you guys reckon go to the wreckers and get a new regulator yeah??
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4077905
No longer need help with this! Thanks everyone for your ideas I got some really good quotes from RAC Auto Service Centre's if anyone has the same problems and you don't have to be a member.
Btw in the crash, the pen still held the window in place!! :P *Props to Bushman Mechanics*
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4094889
On this window topic... Does anyone know of a place that buffs scratches out of windows? places like O'Brian etc don't do it anymore because it thins the glass and affects the structure of the car.. but i just want the driver's and passenger's door windows done.
https://www.sau.com.au/forums/topic/231729-window-fixing/#findComment-4095109
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
