Ok wrong forum and all that stuff, however i thought some of you guys may know (IMMACUL8, Paul, GTRKEN etc)
I've been offered a good quality, 3" turbo back, S/S exhaust for $800. Its about 6-8mnths old and is supposed to be in very good condition. Sounds great etc
Second hand seems like a good option at the moment
Main questions are:
Its coming from a near stock 2000 club spec 4, so will it fit a MY97, without any hassles?
How easy are they to fit? and
Is this worth it, or should i shop around some more?
Cheers,
Mat
https://www.sau.com.au/forums/topic/23173-wrx-exhausts/
Thanks guys...
Dont worry SkylineGTR, i knew what you meant! :D
APPARENTLY it will fit no probs. Im not sure though. I'll PM Ken i think, Paul.
Would love a titanium exhaust but cant really afford one just yet. He's got reciepts and it was almost 2G all up. Its under a year old and is fully stainless steel.
If it fits ok, i think i'll get it.
Does anyone know how hgard are they to fit??
https://www.sau.com.au/forums/topic/23173-wrx-exhausts/#findComment-498341
Docile , all WRX exhausts on the 94-2000 fit but get one that is from the turbo back ( not cat back) and make sure it has a separate or blended waste gate pipe. That is where the gains are..
Maximums sell a show quality one from the turbo back in Stainless steel , hi flo cat and a nice tip with a muffler that doesn't drone for $1750 + GST fitted.
Biggest hassle is getting the pipe off the turbo and modifying the steel cover to fit the bigger pipe.
The rest is easy and a hoist makes it a lot simpler.
Cheers
Ken
https://www.sau.com.au/forums/topic/23173-wrx-exhausts/#findComment-498426
Thanks heaps Ken. I have a feeling it was either a MMS or RMS exhaust... He said he payed around $1800 for it.
Its turbo back, so if its looks the goods, i'll buy it
I've got access to a "walk in pit" but my old man knows a couple of guys that run the Shell garages, so we could probably borrow a hoist for a little while.
The only bit i'm worrying about is "getting the pipe off the turbo and modifying the steel cover to fit the bigger pipe"
Any ideas on a rough figure of an exhaust shop fitting it??
Cheers
Mat
https://www.sau.com.au/forums/topic/23173-wrx-exhausts/#findComment-499109
dolice....
what modification do you want to make????
I have a MMS turbo back (all MMS are Norm Bulter built). The way to tell if its MMS i it will have a wastegate splitter built into the dumppipe (this is where the power gains come from as Ken was saying)...
To fit it its a piece of cake. We did took mine off 2 weeks ago, fitted my ew turbo and put it back on ourselves.....
Daniel
https://www.sau.com.au/forums/topic/23173-wrx-exhausts/#findComment-499168
Daniel, I just want to run autronics, FMIC, big turbo etc. Thats all in the long run though.
For next 6mnths or so i just want to have the very basic mods.
I'll sms him soon (he's selling because he bought all Rashaad's (the spoilerless evo 4 rex) old stuff, when Rashaad bought Hansens Evo 6) and find out.
https://www.sau.com.au/forums/topic/23173-wrx-exhausts/#findComment-499178
Ok cool. He was saying something about having a splitter and wanted 1K for it (but whilst drunk at the ISD's he said i could have it for 7 or $800), so i'm going to buy it.
I know only the basic's so anyone with help / idea's / advice on changing exhausts, it would be much appreciated!
https://www.sau.com.au/forums/topic/23173-wrx-exhausts/#findComment-499376
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
